Question about Leadtek Computers & Internet
Winfast cn15325 diagram
Power switch connections
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
Can't remember how the adio connectors connect
Good day sir, you plug the audio cable at the bottom left of the board, shown below and to the back left side of the DVD drive. Hope this helps.
Aug 31, 2009 | Computers & Internet
Winfast n15235 motherboard manual
Mother Board ECS or MSI,Processor AMDuron 2.8 Dual Core w/1333 FSB,1 to 2Gig DDR2 PC667,160 to 250Gig Hard Drive Seagate Barracuda(7,200rpm) or Western Digital,CD/DVDwrite,512Video Card inno3D/Nvidia or ATI Radeon,LG or Samsung,Tower Casing w/ ATX Power Supply 500 to 600watts and LCD/Flat Screen 19inches wide screen or it up to you what you size LCD..Thanks..^_^
Jun 26, 2009 | Computers & Internet
Winfast mother board with sis964 chip and socket 754
you must reset bios either by removing M/board battery for 1 or 2 hours or via the reset pins on M/board
Aug 06, 2008 | Computers & Internet
Winfast 760GXK8MC 754 SEMPRON aTHLON 64 pROCESSORS
disconnect all external devices and then bypass the UPS and plug the power cables, monitor and computer, into wall socket outlets. Make sure and disconnect any ethernet cable as well.
Jun 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
MoBo Winfast 6100M2MA-RS2H
This board is made by FoxConn.
Looking up towards the CPU from the bottom the front panel connector is the third connector up from the bottom right and/or should be labeled as show.
This motherboard is made primarily by FoxConn
This is the link to the English Manual download page.
Regards,
Worldvet
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Leadtek Computers & Internet Experts
Cliff
Are you a Leadtek Computer and Internet Expert? Answer questions, earn points and help others
