Panache tv has sound but no picture can you advise please
The television was working this morning and when switched on tonight there is sound but no picture. it has been in use for 13 months
SOURCE: No Picture on Viewsonic TV
That is a coincidence. My tv went out the same night. But mine wont even turn on at all. So far I have had no luck finding anyone to repair it. Let me know if you figure something out and I will do the same.
Posted on Jan 16, 2008
SOURCE: no picture just sound
Had the same problem, took the back off and found some bad soilder joints on two of the main circut boards. Re-soildered and appears to be fixed.
Posted on Sep 09, 2008
Had a problem with 32'' viewsonic.No picture and had sound.Fix is a chip on power supply($15.00) part.I replaced and all ok now.
Posted on Nov 07, 2008
  • 718 Answers
SOURCE: have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: 42" LCD TV no picture.Have sound
inverter panel is faulty you can probably source another via ebay if your confident on fitting it could be expensive otherwise
Posted on Dec 12, 2009
How do you set the tv source on the Panache tv to start on HDMI mode when you switch the tv on
Please go through guidelines given in the operation manual of the TV
Jul 15, 2012 | Televison & Video
My vizio VW42L has a picture, but the sound went out....how can we get the sound back
Use your remote and find RESET from the settings. I have a tendency to reset the sound on my TV's with all of my remotes, sometimes a different remote for a different TV or stereo will do something funky and turn off my sound the only way to get it back is to reset the settings and reprogram the channels.
Nov 19, 2011 | Vizio L32 32 in. LCD HDTV
No picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Jul 24, 2009 | Sony KV-36XBR250 TV
Samsung tv wont come out of standby
Not expensive but very hard to find the exact problem.
Both are not the same problem.
Mostly, your case related IR module problem.
the other below, yours are poewr board or thermostat problem.
Jan 14, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
50" Plasma HDTV
Hello ndulgebeauty,
This sounds like a power supply problem. I would advise that you get a qualified TV technician to troubleshoot this problem. The reason being is that the TV does not come on at all. The problem might be the main power board (AC to DC) or the secondary power board (Switching Power Supply and distribution board). Have these checked first.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Televison & Video
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Rca d52w19 power but no picture...
Solder around flyback pinns this should fix it.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
No picture
Same problem, worked fine this morning and then tonight I million green horizontal bars - sound is fine. I think from reading up on this we are doomed. I am so pissed, the TV is not even 2 years old.
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
