Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawn mower R484P
I need a technical diagram of the springs and levers for the throttle. The mower was not responding to the throttle and when I looked at it the springs and levers are not attached to the bits they should be but as I have no idea where they should be I am stuck.
A diagram or photo would be great.
My email is jletchford@talk21.com if that helps.
    Problem Solver:
  • 7 Answers
Why not let Black & Decker dealer service take care of if for you?
I have used their service on my 14-year old Black & Decker mower on the few occasions that I needed repairs and paid a very small price.
Posted on Nov 01, 2008
Governor linkage on toro snowthrower model#38415
If I cross reference the engine correctly it is a TEC HSK 850 so the follow service manual should be what you need.
Nov 03, 2014 | Garden
How to install throttle control spring on Honda GVARA lawnmower engine
There should be an empty hole in the throttle lever that one end of the spring goes into. The other end is attached to a stationary post directly in line with the throttle lever. Hook the spring in the throttle lever first and look for something to hook the other end on, probably in the direction away from the engine.
Aug 23, 2014 | Garden
Where does the throttle linkage spring attach on each end on a Yardworks 173cc 21" (Model# 11A-A2M7515)? I was mowing the lawn and pushing the mower close to a tree and a branch popped off the spring.
there is a little tab behind the air filter but facing forward. it is a funny shape. hook the spring end over this tab and you should be good to go
Jun 29, 2014 | Garden
My Victa push lawn mower won't shut off. Throttle cable pulls back but won't push forward and springs underneath housing seem extremely loose. What do I need to repair/replace?
Sounds like the inner throttle cable is binding with the outer casing,
This coule be caused by dust and moisture causing rust on the inner cable. I would firstly try to get a light spray lubricant into the outer casing .
I would disconnect it from the throttle lever and spray lubricant onto the inner cable and progressively work the throttle lever to draw the fluid into the outer case. Elevate the lower end so gravity will assist you.
Feb 03, 2013 | Garden
Give me a diagram of a 3.5 briggs-stratton push mower
If your lawn mower has no throttle lever, it is most likely the throttle spring. it is too tight or too loose, you will have to *play* with it to get it right, or even replace the spring. hope this works..
Sep 01, 2012 | Briggs & Stratton Garden
Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
268 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
