Question about Sony Playstation 3 (PS3) Console
Red blinking light on playstation 3
After I have switched it on the light is green and then a minute later it switches to red and blinks. The vents are free from dust as the console sits on a table top allowing plenty of circulation. I thought it could be a overheating issue. There is no disc in side as I managed to eject it. From what I,ve read it could be solder that has melted onto other components and connecting.
  • 1,188 Answers
Here is some info that I think will help you solve your problem:
PRLog (Press Release) - Jan 27, 2010 -
If you are dealing with the PS3 red flashing light problem, you are likely wondering if there is really an affordable solution out there. If you have heard that Sony charges a minimum of $150 to fix the problem or have called them yourself and discovered this charge, you are likely on the verge of tossing your unit out with the trash.
Don't do it!
You can fix PS3 red flashing light problems and it doesn't have to cost that much. You may have paid hundreds of dollars for your gaming system, but there is absolutely no reason you should have to pay that much again just to keep it functional!
It's true that the systems should be functioning better than this, but you can't change that right now. What you can change is how you fix the PS3 red blinking light problem and how much money you save doing it.
You essentially need to go through two steps to fix the problem: analyze potential causes and find a step by step complete guide from good ylod fixer sites like http://www.ylod.net/.
Potential PS3 Red Flashing Light Causes
In most cases, PS3 yellow and red light flashes are caused by damage to internal components such as the motherboard. Overheating tends to be the most common issue, but there are some other small little reasons.
You can pretty much narrow it down to overheating if you noticed your console sounding louder while in use prior to the red flashing light issues or if you regularly noticed that it felt very warm or even hot. Also, if you have your console flat down on the floor or up against the wall chances are high that overheating is the issue, since the vents are blocked off in this position and ventilation suffers.
Finally, if you notice a bunch of dust collecting on the console and in the vent, that can block off ventilation as well and lead to overheating when the console is in use.
Another possible cause of red lights flash is damage to the hard drive. If you can replace the hard drive with someone else's which you know works and the problem is not fixed, then you know that is not the issue.
PS3 Red Flashing Light Fixes
Once you have a pretty good idea of whether the problem may be caused by internal damage or the hard drive, you can weigh your options for fixing the red flashing light issue of your ps3.
The hard drive can simply be replaced if you think it is that, but in most cases you will need to either send your console in for a fix by Sony (last for 6 weeks) or use a reliable online program to fix the problem on your own.
There are several advantages to doing the repairs yourself with an online program:
1. The program is available for immediate download.
2. The program will cost a small fraction of what Sony will charge you.
3. You will have everything you need to fix other possible PS3 problems in the future.
The trick is to find a program that gives substantial assistance and customer service and which gives information for fixing other PS3 problems like red screen showing up, complete freezing problem etc apart from just the red lights flashing problem.
Good programs not only teach you how to troubleshoot your PS3 and repair all the yellow and red lights blinking issues, they also update you all the necessary improvement on your Ps3, which will make your system more functional when you get it up and running again.
On the other hand, http://ipad2freedownloads.weebly.com/ is a great starting point to research free movies, games, eBook heaps of different apps for your iPad. This is the largest database system on the internet, so you will stumble on here all of the most recent device for accessing the biggest file network on the planet. It will proffer you with little by little instruction, software and 24/7 technical support in which you can make inquiries if you have any problems.
Posted on Feb 16, 2012
My Playstation recently completely switched off while in the middle of a game, then after trying to switch it back on the green light would come on for two seconds then turn back to a flashing red light....
A blinking red light indicated a hardware malfunction or overheating problem. Let it sit over night and next time you turn it on make sure you feel air flow through vents. Another step might be to blow some compressed air into the vents to unclog any build up of dust or dirt. If this fails to solve the problem call sony to have them fix it as it might be a more serious problems such as a fan failure or internal hardware malfunction.
Oct 13, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 blinks red when you turn it on
Again, people assume because it is blinking red that it is the "YLOD", better known as a hardware failure.
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Good luck......
Aug 16, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power supply switch off red light blinking on
its not the power supply. your cpu needs to be reflowed
May 31, 2010 | Sony PlayStation 3 40GB System
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
PS3 won't stay powered up.
powersupply is bad. ebay has them for around 45.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Red Blinking Light
This is a general warning code. Try switching off the power in the back of the system, waiting a minute, then switching it back on. Try turning the system back on and see if it happens again.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
My PS2 has red blinking light
Your thermal sensor is damage. Do try replace it . It is situated nest to the processor
Jul 01, 2008 | Sony PlayStation 2 (PS2) Console
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
