Question about Pool & Spa
I have an Aquatherm AT600 pool heat pump with a bad defrost sensor. does anyone know wher I can get a replacement sensor?
2 Suggested Answers
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Posted on Apr 22, 2010
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Bearing size swimline pump 0.75 Kw
don't bother replacing if bad bearing motor soon behind and the heat from the bearings pump will start to leak soon replace whole unit
Apr 28, 2013 | Swimline Pool & Spa
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Aquatherm pool heater
make sure it is connected to the solar to get it to work
Jan 06, 2013 | Jandy Digital PoolSpa Control w Actuators...
Heat pump only runs for a few min in heat mode, then switches to cool and will not produce warm air until the system is turned off and back on.
The defrost sensor or timer is bad. When the heat pump runs in heating mode the outdoor coil gets very cold and needs to defrost every four hours or so. When it does this it goes into cooling and turns on the auxiarlly heat.
The unit will have to be checked to see if the timer is just going right into defrost mode or if the sensor is telling it to go into defrost mode.
It probably would not be a bad idea to just replace the both pieces since they work in conjunction with each other.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 25, 2009 | Heating & Cooling
Aquatherm pool heater runs but not heat up
Did you replace the dryer on the unit?
Oct 27, 2009 | Heating & Cooling
Pool heat pump won't keep running
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Mar 03, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Pool & Spa Logo
126 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
