Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl washer spins during wash cycle
Wash tubs spins during wash cycle causing clothes to create an out of balance. How to stop of fix?
Lid switch is bad
Posted on Feb 15, 2012
  • 94 Answers
SOURCE: clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Posted on Oct 17, 2007
SOURCE: code dc appears and has trouble draining and spinning during last 12minutes
The code is dc not fl for the flow problem do I have to claen the screens
Posted on Mar 08, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Tl washer
Mike, Sorry to hear that, is there any water around the clutch pulley?  With the front panel removed and you put the washer in a Spin Only cycle with no clothes in the wash basket.  View the Clutch pulley turning CCW and see if is turning true with no wobble? Mine spun off twice before I got it seated properly, and it was in wobble mode until I got it seated properly.   With the water leak issue maybe you can view with the front panel off and a partial fill the leak source. You can always do a quick tub pump out in service mode. As you know unplug the 120VAC to the machine before you poke around in there.  Do you still have the original clutch?  Did you remove the plastic cover and inspect the roller bearings, clutch spring and coupler? Good luck and let’s see what you find. Rich
Posted on Mar 12, 2009
SOURCE: maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Posted on Mar 27, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL stops spinning mid cycle? The washer stops with 11 to 13 minutes from the end of the wash cycle and leaves water in the wash tub. We've tried shifting the load for balance but it does not...
RF_Tim
I feel you have a Clutch malfunction a very common problem with the machine. If you want to DIY the fix see my Clutch Fix post.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you need some additional help just shout back……..Rich
Jun 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL FAV6800AWW stops on the spin cycle (~11 min). I can see and hear the tub tumbling kind of hard even though it has small amount of clothes. I already removed the clutch and lubed with...
Thank you for posting your Model number very much appreciated. Did you follow my Clutch Fix post for the clutch maintenance you performed? Did your Clutch Pulley use the upper bearing ring as I show in that post? When you stop on Spin Cycle do you have an unbalance error code such as dC or uC. What are the first two digits of your Serial Number it will be 10 thru 17 range. I?m an owner and will I?ll try to help?..Rich
Apr 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Strut testing on Maytag Neptune TL FAV6800A
Check damper pads then replace if necessary. These pads prevents the washer from violent vibration. It is located beneath the main support housing on the base of the washer.
Aug 21, 2009 | Maytag Washing Machines
My wash spins SO loudly
Had the same problem with my Neptune and is was not the bearing (there's only one). I replaced my washer with a new tub and bearing which was factory pressed in the tub (couldn't just by the bearing) after all this I found that the spinner support (which has three arms holding the tub) on the back of the tub had one of the three bolts broke and was throwing the washer out of balance and creating a loud knocking sound when it would spin. Replaced the stainless bolt and everything was fine. The repair man told me what he thought was wrong with my machine so I did the repair myself and found out after the fact that I wouldn't have had to spend all the money on the new parts if I would have just investigated the problem further.
Sep 12, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
161 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
