Question about Canon PIXMA MP970 InkJet Printer
Canon PIXMA MP970 PGBK does not print
Tried cleaning, deep cleaning, and print head alignment. With auto alignment, get message "Auto head align has failed". Manual head alignment never prints the black. Removed print head and cleaned with 50/50 ammonia and water then performed deep cleaning a number of times along with print head alignment but still no PGBK. Any suggestions are greatly appreciated?
  • 2427 Answers
SOURCE: Color is off...too much red
Your color profile is off
Click on start / printer and faxes
right click on your printer and select properties
click on the color management tabe and selct another color profile
If that dont work
in the printing preferences (propteries) adjust the amout of maganta(red) down a bit to compensate for the rest..
but the problem is your color profile
Posted on Dec 31, 2007
SOURCE: Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Posted on Jan 26, 2009
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
komguy
  • 2306 Answers
SOURCE: Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Posted on Jun 25, 2009
SOURCE: Canon MX 700. I cannot get print alignment. I am
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Posted on Sep 17, 2009
How can I get it to print?
Try unplugging from your computer, uninstall printer on your computer and reinstall.
Add or remove printer
Jan 09, 2016 | Canon PIXMA MP830 All-In-One InkJet...
Why wont the head alignment work?
If the inks will not come out the alignment fails. Have you tried a deep clean? If that does not solve your problem
You can try and soak the head in one oz. ammonia and 8 oz. of hot water. Preferably distilled or spring water. Make sure it covers the nozzles and ink intake ports. Let it soak for 30-45 minutes.
Completely dry the head and contacts being careful of the nozzles
.Maybe let it sit for an extra few minutes
Do a deep clean after installed and if it now does a nozzle check be sure to put paper in the top tray and do an alignment.
If this does not work you may need a print head which I can supply.
Thankls for using Fix-Ya
Aug 26, 2014 | Canon PIXMA iP4300 InkJet Photo Printer
Auto head align Fails screen says "change H
You need to print an alignment page. After you print it, you will be able to align the page using the up and down arrows.
Jan 27, 2011 | Canon PIXMA MP780 All-In-One InkJet...
The pgbk on the Nozzle Check Pattern doesn't print at all. also the Auto Head Align failed
It means you either need a new printhead, QY6-0061-000, or the purge assembly is worn out and not cleaning or priming the black properly. You can change the printhead but the purge assembly is a shop repair.
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP970 how to remove print head to clear small pieces of stuck paper?
Make sure the unit is powered off before continuing.
On the right hand side of the print head holder - just to the right of the print cartridges is a lever. If you raise this lever the print head can be removed. When you have cleaned off the debris carefully replace the head and then lock the lever in position. Then run nozzle check, cleaning cycle then a head alignment process before printing again.
Oct 01, 2009 | Canon PIXMA MP970 InkJet Printer
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP970 InkJet Printer Logo
1,033 people viewed this question
old marine
old marine
