Question about Maxtor Hard Drive
Fixed slave/master settings, installed, but
Have the Diamond 20. I installed, see the master, slave correct settings in cmos, why do I not see new D drive listed in "my computer" area along with my reg. C drive?? I need to clone drives asap. Only 420mb left
  • patnelligan1 Oct 25, 2008
    I first just want to know that my 2nd maxtor hard drive should show up in "my computer area". Right?? It doesn't, yet it does show up in cmos, win xp device mgr-diskdrives. The pin is set right for cable. Please help
  • 94 Answers
Hi patnelligan
check inside your system BIOS (cmos settings) and look for plug and play OS setting, make sure this is set to Yes also you could try setting the jumper on your slave drive to cable select
hope this helps
Posted on Oct 25, 2008
How do I install an extra SATA cd/dvd drive in my PC
Hello, I will be the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Peter Symonds.
Read the big label that the manufacture has put on your DVD drive, you need information regarding Master and Slave jumper positions.
You need to set the main DVD drive as Master and the other as a Slave or secondary drive. However some-times this configuration is set in the BIOS/CMOS of your computer system.
Install the drives by removing an available 5.25" plastic drive cover on the front of your PC tower case. Now secure the new DVD drive to the chassis with the included M3 mounting screws.
Use two screws on each side to ensure that the drive is secure.
Insert both the SATA power and Data connections into the drive and the SATA data connector into an available SATA connector on the mainboard.
Once completed power on your computer and enter the BIOS/CMOS by tapping the delete key as soon as your computer powers on.
Your will get to the BIOS/CMOS screen where you need to find the heading for Master and Slave drives. You should see your primary hard drive and both DVD drives.
Enter into the DVD drive settings and set the one to master and other to slave.
Save and exit setup, usually F10. Read options at the bottom of the BIOS/CMOS screen.
It's as easy as that.
Take care!
Jan 30, 2012 | Dell Dimension E520 PC Desktop
Installation of the drive and setting of jumpper to make it either as a master or slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 27, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Clutch pedal goes to the floor.
hydraulic clutch? something is leaking in the bell housing
Sep 12, 2009 | 1988 Isuzu Trooper 2 Door
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
on the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Oct 23, 2008 | Maxtor Hard Drive
Video and photo files
Dear Friend,
Point your browser to
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
or
for more drives to
Alternatively
JumpersMAXTOR DIAMOND MAX INSTALLATION SHEET
Jumper Setting
+---+---+---+---+---+ |J50|J48|J46|J44|J42| +-------------------------------------+---+---+---+---+---+ | Master/Slave | | | | | | | Only Drive in single drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Master in a dual drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Slave in a dual drive system | O | | | | | +-------------------------------------+---+---+---+---+---+ | Cable Select | | | | | | | Disabled* | | O | | | | +-------------------------------------+---+---+---+---+---+ | Enabled | | J | | | | +-------------------------------------+---+---+---+---+---+ J=Jumpered O=Open *=Default
Feb 05, 2008 | Computers & Internet
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
