Question about Microwave Ovens
Ge jvm 130001 no power
Plugged in no power
Ge microwave # JVM 1660 = beeping problem
see this video and proceed according. God bless you
Oct 01, 2012 | GE JVM1660 Microwave Oven
The Cook Time I use to work, not it wants a code and if I put in a number it will start. But I can't set a cook time or power level. The Cook Time II works ok, except I can't use the number 1; defrost...
Is it possible that some cleaner got into the controls? That'll kill them quickly.
Hopefully it will dry out on its own. I'd unplug it overnight.
If not, then either there is moisture on the control board (which can be dried or allowed to dry) or in the layers of the membrane keypad.
But the membrane keypad may not be available any longer. It is part number WB27X287 and if it still available, it may take a week or so to get it, it will probably be about $150-180, and you can try to order it from the Pros here, the Sears Parts Direct Web site image-4235112-10659157 or from Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We do board repair, so let us know via our site if we can help further.
Dec 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
Mar 21, 2009 | GE Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
