Question about Honeywell Heating & Cooling
My new th942c1004 stat is frozen after it has been working fine for 2 weeks. any idea how to get touch pad to work
My stat has all the displays but the touch screen is no longer working.the stat is 2 weeks old and the lock function was not programmed in.any ideas?
SOURCE: frozen pad buttons
I have the same problem but it's 1, 4 7. I squeezed the edges of the keypad and it seems to have aligned things up again.
Posted on Feb 18, 2008
  • 79 Answers
SOURCE: Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Posted on Aug 20, 2008
  • 207 Answers
SOURCE: rainbird controller lock up
You need to replace your controller.
Posted on Jul 09, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Nov 25, 2009
Two finger scolling fix
Try to re-install the driver for the touch pad, you can find it at Toshiba's official website
Feb 04, 2013 | Toshiba Satellite Computers & Internet
My Kenmore Elite model 66463 has the following buttons that stopped working....1-7, soft, melt, bread defrost, express defrost, frozen entree, frozen vegatables. All other buttons and microwave heating...
Sounds like a bad touch panel. They run silver oxide traces through that panel and they couple a lot of them together. So if a trace common to those pads breaks you lose all the pads connected to that line So Probably need to get price and availability on a new touch panel.
Aug 12, 2017 | Kenmore 66463 Stainless Steel 1200 Watts...
Touch pad on front frozen up
The machine is a "computer" and needs to be repaired by the dealer.
Mar 14, 2010 | Husqvarna Designer I
My touch pad seems frozen, yet all else works fine, what do have to do to get enabled again?
There is a button on the laptop that disables the touchpad. Press it. Or it might be Fn + one of the function keys.
Aug 14, 2009 | HP Pavilion dv1000 Notebook
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Frozen media tochpad on acer 6920
NO!!
bad idea, mine locked up, then i forgot my charger, battery died and stayed dead for a day or 2 then when i charged it again the touch pad was fine, all you have to do is reset your laptop, by removing the battery for a little bit, not sure how long is really nessicary but 1 hr should def. do it! hope its not too late!
Nov 01, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Kenmore elite model165.15989990
Replace the control electric first.If you have visual crack/cracks in touch pad then you have to replace it also.
Apr 01, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Problem diagnosis please
touch pad is stuck on the control panel machine putits self in self test
Mar 03, 2008 | Washing Machines
Touchpad Not Working
is there a touch pad 'switch' off function with this particular model? Some Acer machines have an F number plus another key to de-activate/reactivate touch pad. Check your Manual
Jun 19, 2007 | Sony 4-660-223-01 Touchpad Keyboard
Heating & Cooling Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
