Question about Rta International Patio Heater
Patio heater we have twoof the large heaters and we got them for christmas last year from our kids . now this year the valve won't turn so we cannot get them on . where can we get parts for them ? asap wisconsin
2 Suggested Answers
  • 185 Answers
SOURCE: I have an RTA International
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Posted on Feb 07, 2011
Patio heater goes out
If your patio heater goes out when you turn on the pilot and let go, this is usually a worn thermocouple. They last between 1 year (if you are unlucky) up to 6 years and are a consumable item. Found this site very useful patio heater problem solving.
May 24, 2012 | Dayva HS041 (LP) Open Flame Gas Patio...
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
MY ENDERS PATIO HEATER i CAN GET TO PILOT ON, BUT WHEN i TURN THE VALVE TO TURN IT ON, IT DOESN'T TURN ON
Most likely cause will be a worn thermocouple, these can last from 1 year up to 5 years but will at some point need replacing. Always check for leaks when making any repairs, found this site very helpful patio heater problem solving.
Nov 16, 2011 | Enders Colsman Enders 90 Inch Black Patio...
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Patio heater phs won't ignite
Hi, First check if you have a full tank and that the pipes are clear of any insects, water or debris. Next see if you have a spark where the pilot is, if you can hear the piezo clicking but cannot see a spark then check the lead. Sometimes the lead can get loose and short out lower down and prevent the spark from reaching the pilot. You may need to take the lead out to fully check. If you have a spark and gas is reaching the pilot then check the tilt switch, if faulty it can turn the gas valve off. To check you can just short out the tilt switch, found this site very useful patio heater problem solving.
Oct 01, 2011 | Endless Summer 2009 Open Flame Patio...
I have a giordano heater that won't light. There is a narrow pipe that diverts gas to the igniter spark. The pipe is capped by a small metal regulator with what looks like a very small hole in it to...
Never drill or try to make the pilot hole larger, this will cause a large flame that cannot be controlled. Check the main parts, first see if you have a spark, next check for leaks, to see how to do a leakage test see patio heater problem solving page. If no leak try changing the thermocouple, these will wear out and can last up to 6 years. Also check the electromagnetic valve that sits inside the gas control valve and if fitted check the tilt switch works. The tilt switch can be shorted out to see if it works.
Aug 03, 2011 | Stainless Garden Sun Steel Propane Patio...
I have afrontgate propane patio heater and the pilot lights but when I try to put it into position to warm it goes out and will not stay lite.
Most common problem is a worn thermocouple, this will cause the pilot to light but go out when turned to full. There can be other issues but start by changing the thermcouple as these generally last between 2 to 6 years. If it still has problems check the tilt switch by shorting it out, found this site very useful, patio heater problem solving.
May 19, 2011 | Frontgate Stainless-Steel Outdoor Patio...
Frontgate patio heater, serial number 01A02 0023562, model number SRPH02, cust number SHCDPH, pilot light won't light (checked gas tank already)
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
May 18, 2011 | Frontgate Stainless-Steel Outdoor Patio...
I can light the pilot light, but there is no gas flow to the heating element, thus heater will not light. Looking to replace control value, but can't locate one online. Where can I go to order new...
Gas control valve are very robust and will last last for years. If the pilot is not lighting the first thing is to check the fuel line from the cylinder up. Always run a leakage test as this will cause problems if you have a steel pipe that runs inside the pole - these can get loose and gas leaks from the locking nut. Use some plumbers tape/seal, for info on problem solving and leakage test see patio heater guide. Also check your tilt switch and try shorting it out before changing the gas valve.
May 12, 2011 | Napoleon Lifestyle Collection Bullet Model...
The pilot goes on but when i un-depress the gas knob to turn the burners on it goes out..hence no flame. what's teh problem?
Generally this is caused bu a worn thermocouple, these last form 2 years up to 6 years but will wear out at some point. For help see patio heater problem solving, these patio heater specialist have helped me in the past.
Mar 03, 2011 | Endless Summer Blue Rhino 235000...
Rta International Patio Heater Logo
32 people viewed this question
Top Rta International Heating & Cooling Experts
Mike
Steve Wood Plumbing...
Level 1 Expert
Paul Carew
Are you a Rta International Heating and Cooling Expert? Answer questions, earn points and help others
