Question about Casio DL 250LA Calculator
How do I load paper into the Casio DL-250 Printing Calculator?
Add paper
MATRIX_MMX
  • 209 Answers
SOURCE: loading paper tape
dear ednacharles
Well i would say to try going to various support websites for this make and model of device, and certainly customer support at casio might be a good place to start. If the device is somewhat obsolete now and you are not getting any joy with the guys at casio, then i reckon its going to have be a nice search on google, and under the search term i reckon it will have to be instruction manual, followed by your device/ make/ model number of product you have. This is what i would recommend as the silly little pictues that come in the instruction manual (no bigger than a credit card) often dont help at all, and sometimes can make the situation worse. thats why I avoid the paper manual and go electronic.
If push comes to shove and you really do get stuck on this (more stuck han a wee little piggy in deep mud) then you can try scanning the manual into a computer scanner, enlarging the image and go from there. Its a bit extreme, but i find it works, and not many people think of it, but trust me, image enhancement is the way to go with postage stamp size instruction manuals.
Of what I know about that type of device, there is usually a slide clip that is moved in order for the new/ replacement tape or paper roll to be fitted, and this then locks in place, and it may be worth knowing that the paper feeds under and over an ink roller that is located near the replaceable/ refillable cartridge. The paper roll may attach to the rear of the device by means of a spring loaded bolt that you pull open to change the paper roll, and should the device block up, then either press the feed button, or gently pull the paper through the top opening if you can see it, or from the back if you cannot get to it from the top.
I hope that this information was useful, and I hope to hear from you soon to find out how you got on
Best wishes and regards
Yours sincerely
OZ
P.S.
you can reach me here practically all of the time if you have any comments or questions. I will always respond
Posted on Apr 10, 2008
SOURCE: casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Posted on Jul 22, 2008
SOURCE: can not load paper
Solved by itense perseverance!
Posted on Feb 13, 2009
jackcity
  • 34 Answers
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
SOURCE: I have a borrowed Casio FR 105S printing
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Posted on Feb 14, 2010
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Feb 05, 2010 | Casio HR-8TMPlus Calculator
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
Can not load paper
Feb 11, 2009 | Casio HR-8TMPlus Calculator
How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Oct 10, 2008 | Canon P23-DHV Calculator
Casio DR-T220
Jul 22, 2008 | Casio DR-T220 Calculator
Casio DL 250LA Calculator Logo
122 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
