Question about Kitchen Appliances - Others
I have a currys essential cdw60w10 dishwasher it's
SOURCE: LG Dishwasher Model LD-4120M Error 0E
LG 2050 error 0E error. - You may not want to believe this but it is true!!
My dishwasher has failed with 0E error 5 times now - it has cost me R350 each time - the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Good Luck - Alan
Posted on Oct 31, 2009
  • 161 Answers
SOURCE: My LG Tromm WM1814CW is not draining. I cleaned
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Posted on Jan 27, 2010
  • 62 Answers
SOURCE: Dishwasher won't drain
pop out the plug where the hose hooks to garbage disposal
Posted on May 01, 2012
caroldon
  • 17130 Answers
SOURCE: Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jun 29, 2012
  • 155 Answers
SOURCE: I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Posted on Aug 03, 2012
I need user instructions for currys essentials CDW45W16 slimline dishwasher. Please can you help?
Partmaster.co.uk has the Curry's essentials CDW45W16 dishwasher manual. The direct link to the manual is https://www.partmaster.co.uk/images/mediator/1513/currys%20essentials%20cdw45w13.pdf . I found this through a Google search for CDW45W16 manual.
I hope this helps.
Dec 09, 2016 | Dishwashers
My cdwtt11 says could be white residue because salt setting too low , how do i change salt setting
see
http://www.manualslib.com/manual/845521/Currys-Essentials-Cdw60w10.html?page=15
apparently it is done by the position of the salt reservoir and it is not mentioned anywhere in your user manual for the cdwtt11
a good place would have been on page 18 but it is not mentioned.
Sep 12, 2016 | Dishwashers
Currys essential dishwasher CID45B13 turns on but wash cycle programme buttons will not select / work.
Hi , it sounds like your panel that the buttons push onto is needing looked at sometimes they just need a clean. If you don't know how to do this with the power off and stripping the unit down then i advise you to have it repaired or claim under warranty if it is still in warranty.
Feb 25, 2016 | Dishwashers
Currys Essential Slimline CDW45W10. Why is water not getting hot?
These seem like the siemens/bosch type. There is a heater relay that can go bad. Its in the front panel. Check the relays in the front panel for bad solder or burn marks.
Sep 02, 2015 | Dishwashers
Instructions to get access to the drain pump for currys essentials cdw60w10
The best bet is to go on line to the manufactures web site and ask customer services to let you download the schematic and manual, free of charge. You need this schematic to follow the procedures when disassembling and reassembling the parts.
Mar 16, 2014 | Dishwashers
Currys essentials dishwasher error warning
I have a curry s essentials CDW60W10 dishwasher that isn't completing any wash cycles can anyone suggest anything ? Machine isn't leaking wont select hard spray in cycle or drain
Aug 24, 2012 | Dishwashers
Manual for currys dishwasher cdw60w10
Look for free operation manual downloads online.
Jul 30, 2012 | Televison & Video
ESSENTIALS CDW60W10 Full-size Dishwasher the third light flashes and beeps then the cycle stops
ESSENTIALS CDW60W10 the 2nd light is flashing then it flashes and bleep for about a minute before the machine stops...I cant find my user manual anywhere..need my dishwasher working with my family!!! plz help!!! :(
Jan 04, 2012 | Dishwashers
Kitchen Appliances - Others Logo
97 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
