Question about JVC Televison & Video
Jvc LT-42X579 directv cannot supports 1080p - JVC Televison & Video
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
  • 257 Answers
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Posted on Aug 13, 2009
  • 1121 Answers
SOURCE: When I try to watch a 1080P movie from Directv I
the TV has 1,920x1,080 resolution in HDMI port and check for a DIRECTV Plus® HD DVR receiver (model HR20 or higher )
Posted on Jan 02, 2010
budmrtn
  • 11361 Answers
SOURCE: what would cause my jvc lt-42x579 42 in. lcd tv to
Failing power supply can be one of the causes.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 28, 2010
budmrtn
  • 11361 Answers
SOURCE: I have sound but no video on my JVC Lt-42x579
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 29, 2010
What are the eeprom codes for jvc tv lt-42x579, eeprom m16
The number of the memory IC will be printed on it. Usually, it will be in laser printing. When replace it, be sure to replace with exact number printed on it; otherwise, it won't work.
Will look somewhat like this. May be a DIL type or an SMD type.
Sep 15, 2014 | JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
Can you hook a JVC lt-42x579 tv up to your pc for netflix
It should be as simple as taking an HDMI cable (if your computer has an HDMI output) or VGA (monitor) cable and hooking it into the TV. From there, go to Control Panel and Display Settings, and click which option you want for the TV screen under "Connect my PC to a projector."
Oct 03, 2011 | JVC LT-42X579 42 in. LCD TV
Wiring diagram and board lay out for jvc lt42x579 tv
I have the copy of JVC LT-42X579 service manual that covers the following :
precaution
specific service instructions
disassembly
adjustment
troubleshooting
wiring diagram
block diagram
circuit diagrams
pattern diagrams
voltage charts
waveforms
using p.w. board & remote control unit
exploded view parts list
exploded views
printed wiring board parts list
remote control unit parts list (rm-c2050-1c)
packing
packing parts list
If you want the copy click it HERE.
Jdvillanueva
Sep 29, 2011 | JVC LT-42X579 42 in. LCD TV
No backlight on JVC LT-42x579
The electrolytic caps on power supply needs replace, or the power supply needs replace.
Jul 11, 2011 | JVC LT-42X579 42 in. LCD TV
My screen cracked on the inside wanted to know if it can fix. model LT-42X579 THANKS
No fixing a cracked screen, and replacement is not worth it, you can check places like vancebaldwin.com
Jan 11, 2011 | JVC LT-42X579 42 in. LCD TV
Dull/blurry picture
Sorry but You Don't.
Imagine taking a small Jpeg photo and blowing it up to Billboard size. It will be pixelized and dull.
Same with HDTV's. You can upconvert and adjust til your eyes turn blue, but you cannot take a Standard Def signal and make it look better by showing it on an HDTV. Some Standard Def material is better than others but ultimately what you see is what you get
Mar 23, 2009 | JVC LT-42X579 42 in. LCD TV
Cannot connect my ipod touch
You need to press the [pcon] button while in the iPod mode of the TV. Then use the Touch to select the file you want to playback. It will playback on the TV. Ensure the iPod is set to output video to TV.
Jan 13, 2009 | JVC LT-42X579 42 in. LCD TV
Televison & Video Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
