Question about Exercise & Fitness
My nordic track 2500R incline will not work. The console indicates the level is going up but thing happens. I took the motor to a shop and it works fine. I bought a multimeter and checked out the power supply board voltage and it reads 117/118 so I'm ok there. The treadmill will not calibrate - I've tried. No error lights either to help. What is wrong?
  • Joseygirl
    Joseygirl Feb 15, 2012
    I meant to write "...indicates the level is going up but NOTHING happens". Also, if its the sensor or console, how would I know? And is the sensor located on the power supply board? If so, then I found it and it goes INTO my incline motor. Can I purchase that separately?
    Top Expert:
  • 12,223 Answers
Dear Sir:
Different things:
1) not any signal from the console 2) Possible damaged cable 3) console has failed. 4)motor control board may have failed from a worn treadmill belt and deck 5) the motor burnt out. 6)potentiometer geared to the motor . These can fail or the gearing can slip, giving the console false information
RUN THE CALIBRATION SOFTWARE SEE THE INSTRUCTION UNDER THE HOOD MOTOR, and follow the steps for easy diagnose and troubleshooting., See my Design from block diagram that will help you to troubleshooting. sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
My nordic track 2500R incline will not work. The c - 2_16_2012_6_16_49_pm.gif
Posted on Feb 16, 2012
4 Suggested Answers
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
  • 95 Answers
SOURCE: I have a Nordic Track 2500R Treadmill it still
FitnessRepairParts.com sells spare parts for equipment and they also have a list of fitness service providers which you can search here.
Posted on Nov 11, 2010
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Nordic track reprogram card
have the card checked.. see if its going bad..
Jan 08, 2014 | Exercise & Fitness
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
Cant close my nordic track a2050.... its stuck open...not very space friendly
Does it close part-way? If so, it might be the same thing that happened to me. Make sure the incline is at zero. It will not close if the walkway is raised.
If that doesn't work, you might try disconnecting the incline motor screw (held in by a retaining pin and cotter pin), turning the screw one or two rotations and reconnecting it. I've had to do that in the past, but I'm sure it is not an approved solution.
Jun 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Oct 22, 2009 | Nordic Track Exercise & Fitness
Calibration
My name is Mike; I am a service technician for ICON Health & Fitness, the manufacture of the machine mentioned. While my comments on your problem are geared generally to assist, you are welcome to call our customer service line at 18009993756 for specific instructions if needed.
The first thing to do with any incline problems with a treadmill is run “calibration.” Calibration restores all settings (including the incline sensor in this case) to the factory specs. Instructions to run calibration on your individual machine are taped on the underside of the motor hood. See your manual for removal of the hood. While each machine has specific calibration instructions most new models made by ICON will have similar steps to doing it.
To calibrate the incline you will need to press and hold the Stop and Speed + buttons while inserting the safety key or magnet. Then let go of the buttons. This will enter calibration level 1 which lists some machine information and a console memory test. Press the Stop button 1 time. This will enter level 2 of calibration. To calibrate the incline you can press either incline buttons (either the up or down arrows) and your incline should go all the way up and then all the way down. If this works then take the safety key or magnet out; turn the power off, and unplug it for several minutes. (On a side not you will want to turn the power off and unplug your machine whenever you’re not using it.)
If this does not fix the problem then it can be more complicated depending on the model and motor involved. It can range from the console not sending a signal to a loose wire or jammed motor. If this didn’t fix the problem then I would recommend calling in for further assistance.
Sincerely,
Mike
Customer Care
Mar 24, 2009 | Nordic Track NordicTrack Treadmill, A2550
Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
179 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
