Question about Ricoh FAX5000L Plain Paper Laser
Need to reset counter on a ricoh fax5010L laser had fuser trouble replaced fuser now need to know how to reset
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
JackHeath
  • 1049 Answers
SOURCE: Ricoh service mode to reset
This is the solution from Ricoh website:
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Posted on Jul 24, 2008
  • 95 Answers
SOURCE: Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
Posted on May 26, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Posted on May 27, 2010
Hp cm4540 fuser kit counter reset
allot of the newer HP printers can not be reset they have a fuse in the new fuser when it is installed it blows the fuse in the new fuser & resets the count.
Aug 01, 2012 | HEWLETT-PACKARD CM4540 AllInOne Laser...
But how can i reset the counter after installing a new fuser oil unit
Press {Menu}.
"Menu" appears on the panel display.
Press {U} or {T} to display
"Maintenance", and then press
{Enter}.
The maintenance menu is displayed.
Press {U} or {T} to display "Color
Regist.", and then press {Enter}.
Press {U} or {T} to display "Fuser
Adjust", and then press
{Enter}.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 23, 2010 | Ricoh Aficio AP3800C Laser Printer
Fuser replacement for my ricoh
Generally it is recommended to have a tech do this. the reason being that if you accidently touch the fuser wire the oil from fingers can fritx it. There is a counter to reset but all the playing around to do this ( with a warranty if it goes wrong) is better to have it done by the tech.
Please rate our help to keep the FREE service online ++++
Thank you for using FIXYA.COM
Sep 01, 2009 | Ricoh Aficio SP-C210SF Printer
Purchased new fusing unit for ricoh cl3500n; installed; tried to reset computer by holding escape for 5 seconds; does not clear out error message 'replace fusing unit' ; nothing will print; can not get to...
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Jul 07, 2009 | Ricoh Aficio CL3500N Laser Printer
May 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Replace Fuser error not clearing
Fuser PM reset
1. Hold the 'up' and 'down' arrows together for 5 seconds or longer.
2. Release the arrow keys and press the 'enter' key.
3. Select '2. Engine' - Then go to option '7.'
4. Go to SP7804-016 (PM Counter Reset>Fuser) and execute. Shows results=OK
5. Turn the machine off and on.
All done.
Mar 20, 2009 | Ricoh Aficio CL7200 Laser Printer
Replaced fuser on LANIER SP C210SF, machine still says replace fuser
It is not recomended to enter service mode on this model if a service tech replaced the fuser they owe you to reset this fuser counter. -Carl, Ricoh tech.
Mar 20, 2009 | Brother MFC-9420CN All-In-One Laser...
Ricoh c3000 replace fuser error
try to unplug it from the wall and plug it back in and let me know if this works
Feb 02, 2009 | Ricoh Aficio CL3000 Laser Printer
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Ricoh FAX5000L Plain Paper Laser Logo
52 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
