Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
I have the Siemens SL84A305UC Dishwasher. All of a sudden it stopped cleaning dishes, but everything sounds normal and it fills and drains water, and sounds like it is completing the cycle. In the past when I opened the door while it was actively washing the water would spray out aggressively. Now, when I opened it while it was supposed to be washing I see just a small amount of water coming from the bottom wash blade, and not even enough to turn the blade very far. I thought it was just a clogged filter or something like that, but I removed and cleaned both the small cup and the large screen without any improvement. I then took off the impeller cover and that also spins freely. My local appliance repair shop doesn't work on Siemen/Bosch so I need help to diagnose/get parts. This has been the best and quietest dishwasher I have ever had, so I don't want to just go out and buy a new one. Best Buy doesn't sell these anymore so I would have to get a different manufacturer.
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Siemens dishwasher does not wsh the dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
eqrte
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: My siemens dishwasher bottom arm does not spin to
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Feb 24, 2011
I set the dishwasher Siemens SL84A to regular wash cycle . I hear it click like its going to start, warm water fills the bottom up the tub but it never kicks into the wash cycle. Hit the cancel cycle and...
Most likely issue here is that the door is not sealing properly or the sensor on the door is not working, so it can fill up much as your washing machine does but just as the washer won't spin without the door closed neither will the dish washer. An easy way to check this is to let it fill and then lean or push against the door some and see if it starts, if so then the issue is the isn't sealing properly.
Dec 04, 2013 | Siemens 24 in. SL84A305UC Built-in...
The dishwasher arm on the top is not spinning so the dishes are not getting clean.
The arms on a dishwasher spin with water pressure remove your arm and thouroughly clean and flush through , also check for wear on the arm bushes to see if there is excessive wear , the washers may need to be changed. Check the supply hole to the top arm to make sure it is not blocked.
Feb 07, 2013 | Siemens 24 in. SL84A305UC Built-in...
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
The dishes do not seem to come out rinsed, especially the glasses. There seem to be small particles of food left on them and overall everything seems coated with a layer of gunk. I've made sure that the...
Hi
Daniel
Dec 10, 2010 | Bosch Dishwashers
Hi The dishwahser does not clean properly. There does not seem to be enough water coming through. I have cleaned out the pump and filters but this has not resolved the problem. Getting a knocking noise as...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Please post back for any further assistance.
Daniel
Aug 13, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
heatman101
eqrte
Jun 16, 2009 | Siemens 24 in. SL84A305UC Built-in...
Siemens Model SL84-A - Water will not pump into dishwasher
heres a screen on the inlet to the water solinoid that plugs up with calcium alot of the time. shut off the water and take the bottom panel off the unit and you will see where the solinoid is. take off the water and then take the solinoid out and apart to clean. reassemble and you will be good to go.
Jan 11, 2009 | Siemens 24 in. SL84A305UC Built-in...
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Aug 20, 2008 | Siemens 24 in. SL84A305UC Built-in...
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
170 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
