Question about Coffee Makers & Espresso Machines
Why can't I get the "plastic" taste out of my coffe maker?
I have run gallons of water through my machine. I added a little vanilla to the water to see if that would mask the plastic taste along with brewing several kCups. The finished beverage still has an overpowering taste of plastic. I use this machine at the office and I also have the Platinum at home. It never had a plastic taste and makes a perfect tasting beverage. Help!!!
  • 362 Answers
I run a mixture of vinager and water through the entire brewing process, works everytime.
Posted on Feb 16, 2012
Testimonial: "I called Keurig to see what their suggestion was.The customer service rep suggested the same solution. I used 2 TB of white distilled vinegar with 48 oz of water and ran it through then followed with clean water. The plastic taste is gone! Makes me think they should suggest this process in the owner's manual."
Try changing your milk - Anchor milk often has a 'yukky' taste
Posted on Dec 02, 2012
ginko
  • 19396 Answers
SOURCE: Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Coldcut
  • 1554 Answers
SOURCE: Plastic Smell & Taste
take up smoking
and then you will loose you smell and taste.
every thing is made of plastic and aluminum now.
only a stainless pot does not leach plastic cfc into water when hot.
Posted on Apr 02, 2008
AlmostBob
  • 550 Answers
SOURCE: Coffee tastes like metal
have you tried a different brand of coffee,
Posted on Jul 02, 2008
SOURCE: Coffee tastes like rubber / plastic - brand new
Used the same procedure. Coffee tasting perfect now!! So glad I found this.
Posted on Dec 08, 2011
ThaMp3Doctor
  • 8596 Answers
SOURCE: Coffee tastes like plastic!
Will improve with time. Run lemon juice per every cup of water for the first month or so. What can I say - it's a mostly plastic coffee maker. Also, try using the charcoal water filters.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
How long does it take for the plastic taste and smell to stop? We have gone through 5 gallons of water (after following all instructions prior to use) and it still has the plastic taste and some odor.
a couple gallons should have done it?
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently.
May 15, 2015 | Refrigerators
My new keurig coffe tastes and smells like bandaids or plastic HELP
If it is new I would contact the company you bought it from. Even to talk to them and see what they suggest.
Sep 11, 2017 | Coffee Makers & Espresso Machines
De scale kruig coffe maker
Empty the reservoir of water and fill it with four (4) cups of white vinegar. Run the Keurig WITHOUT a K-Cup until the vinegar has been run through. Rinse out the reservoir with hot water, dry it, then fill with cold water normally used to make coffee. Run the maker 3 times, or until vinegar taste disappears.
Dec 25, 2011 | Keurig B60 Coffee Maker
We love our model E9 coffee maker. However, our coffee has been bitter. In South Florida our water isn't the greatest, but I use double-filtered tap water, and also bottled water. We also use good...
t is most likely the coffe you are using,I would suggest you try different roast from different brands until you find what you like..for axemple Lavazza coffe from Italy has all kind of different roast.
good luck
Aug 25, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Apr 05, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Keep asking to ventilate,when ventilated,coffee does not come out
Run CLR through a couple of cycles and flush with clean filtered water through a couple cycles. Try to use filtered water to prevent lime and calcium buildup, besides, the coffe will taste better - Godd Luck-Ned-
Aug 23, 2009 | Saeco Royal Cappuccino Espresso Machine
I need Oster ice cream maker instructions. I have the Oster Quick Freeze Ice Cream Maker #768-08E, but it did not come with instructions. Any receipes for diabetic ice cream?
http://kitchen.manualsonline.com check out this website for your instructions.
Homemade Vanilla Ice Cream
3 cans fat free evaporated milk
1 quart fat free half and half
1 quart whipping cream
1 cup Splenda
vanilla to taste
Mix all together. Follow directions for electric ice cream maker. Makes 1 gallon. To make chocolate ice cream, add sugar free chocolate syrup in recipe.
Jul 31, 2009 | Ice Cream Makers
Coffee Makers & Espresso Machines Logo
1,793 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
