Question about Kitchen Appliances - Others
Owners manual for Rinnai Waterless Hot water heater R85?
I installed and am now having a problem since yesterday with not getting hot water. But the next time I try I have hot water?? this has happened twice and I cannot find my manual to trouble shoot. I cannot locate the manual on their web site.
  • stanleyla Jan 19, 2009
    When I first run on the hot water only tap I have hot water. However shortly after I turn on the cold water tap the hot water goes completely cold. The unit is approximately two years old. rinnai r85 gas tankless
    VR,
    Mike Poole
    poole-mike@hotmail.com
    504-994-5339
    VR,
  • 19,396 Answers
Here is the manual : Operation / Installation Manual
Posted on Oct 25, 2008
SOURCE:
I have a Rinnai R85 water heater and my temperature controller doesn't have any power.
You will only get power out of the controller when there is a call for hot water. If you have power into the controller, and you still get no power out when there is a demand, then the controller is bad and must be replaced.
Feb 27, 2018 | Rinnai Water Heaters
In temperature screen at 49 degrees to back to front t's appear and boiler stops
PDF]Operation and Installation Manual Outdoor Tankless Water ...
https://www.rinnai.us/.../U287-1932(00)_Outdoor_...
Rinnai America Corp.Temperature controlled continuous flow gas hot water system. .... This water heaterwill attempt to provide hot water at the temperature setting even when the ...
Hot water system temperatures and the code ' Plumbing ...
plumbingengineer.com/content/hot-water-system-temperatures-and-code
Feb 1, 2015 - There have also been incidents where the circulating pump stopped ...before it connects back to the cold water inlet to the water heater. .... Is there a maximum temperature limit for domestic water heaters? ... a means to limit the maximum setting at the valve to 120°F (49°C) or ... Some do and some don't.
[PDF]User's Operation Manual - contents - Navien
Dec 25, 2015 | Water Heaters
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
Takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Jun 12, 2009 | Rinnai Water Heaters
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water - Rinnai tankless hot water heater
sounds like the water line is frozen before it gets to heater. You can take a blow dryer and try to thaw the line.You should be able to hook up a hose on the hot side of water heater. turn valve off so it wont flow into house.You can turn on hot water valve on in kitchen but you will have to thaw cold and hot line. Make sure you know where water shut off is to the house just in case a line breaks.
Jan 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
We have installed a rinnai water heater in the basement. Since it takes a little time before the hot water arrives in the kitchen or upstairs in the shower, we are wasting qite a bit of potable water every...
The only way to reduce water waste would be to have a plumber install smaller pipes coming from the water heater to each individual point of use. The normal way of plumbing a house uses a large pipe that has smaller pipes that go to each sink, tub, shower, etc. The larger the pipe, the more water is in it and the longer it will take to get hot water to where it is going. An electric tank won't save you from wasting any water unless you have a separate hot water circulation system installed. This would keep the hot water drawn out to the far ends of the plumbing system and allow the hot water to reach it's destination alot sooner. However, keeping a tank full of water hot is not economical and a circulation system basically turns your pipes into a radiator causing you to waste electricity. I know it may seem that you are wasting alot of water waiting for the hot water to get there, but in the long run you and the environment are coming out ahead due to the saved energy and efficiency of the Rinnai unit. Also just in case you were thinking of it, a circulating system is not compatible with a Rinnai water heater.
Jun 19, 2008 | Rinnai Heating & Cooling
Rinnai Propane tankless Water Heaters R85e-1
Piping of these heaters in tandem is critical. Specified by Rinnai in their design manual, the cold water should be piped to both water heaters with a back-flow presenter installed before the first heater. The hot out piping should be "Tee-d" together and going to your hot water needs.
If piped as per the manual, try turning the water off to only one of the units. Turn on a hot water tap and see if the unit stays on without interruption. Then try the same on the second unit. You may find that one unit has a bad flow control, which is shutting off the flow of water.
You can get more technical help y contacting Rinnai direct at 1-800-621-9419 ext. 207.
Feb 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Tankless Water Heater
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Kitchen Appliances - Others Logo
2,580 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
