Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain access master chain drive garage door opener
My garage door opener motor will not stop going down even when limit switch contacts touch. It stops when opening fine but not when going down. We recently had a neighbors house struck by lightning and I assume we had a power surge since this has been occuring since then. Do you think replacing the limit switch will correct this problem or could it be a larger problem. Motor, safety sensors and all other components seem to be fine. Thank you.
  • 504 Answers
First unplug the unit for about 5 min. to reset the circuit board. while you are waiting use an ohm heter or multi tester to see is the limit switch works.
If the switch tests good and resetting doesn't help you probably need a new board.
Be sure to also get a suge protector to help save the system in the future.
Hope this helps
Posted on May 29, 2010
Door comes down and goes right back up. then the lite blinks 4 times with a click noise. the safety eyes also are not on
It sounds like you need to adjust your down limit switch and/or perhaps your motor force settings. If the limit switch is not in the sweet spot along the rail it can be triggering too soon or not in time. In your case it could be too far down the rail and thus not stopping/slowing the motor in time. Your door is then being pushed against the floor too hard. Your safety/return force is goes way over limit and tells the opener to go back. While closing your door look at your rail and if its bending when the door hits the ground, this is definitely happening. After finding the sweet spot for your down limit switch, you can readjust your return/safety force per your opener manual.
Jan 03, 2011 | Chamberlain 12HP Power Drive Chain Drive...
I have Chamberlain 1160 Lift-Master farage opener. Currently the trolley stuck in the upped position agains the bolt and does not go back. When I try to close the door, the motor is humming twice, then...
Loosen the chain to remove the strain from it and run the motor until the door closes. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Now you can tighten the chain.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP chain drive garage door opener.
You need to take the cover off the motor unit and watch how the limit switch assembly works. If the door is not stopping when the contacts make then you have a bad logic board.
Jun 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
993 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
