Question about Fuji FinePix F470 Digital Camera
Any way to fool the auto exposure in movie mode?
When i shoot video I would like to under expose the clip to darken the white wall background of the subject is ther any way to fool the exposure sensor to under expose scene?
  • 734 Answers
You have to buy an expensive DSLR? Or, fool around with spot exposure and avoid background lighting. Or use expensive lighting to balance the picture content?
Posted on Feb 16, 2012
How to take pictures of paintings without the image appearing dark using auto focus
It sounds like your camera is under exposing a little. If you can, shoot in "raw" mode, and adjust in the software the camera manufacturer provides. Other things you can do: adjust the white balance for the lighting, override the camera's exposure to get more light, use flash, etc.
Oct 17, 2014 | Cameras
When taking a picture in daylight and the background is bright the background comes out as white-no colour. I've tried fill in flash and also exposure compensation to no avail. Very frustrating-please...
Your camera is setting its exposure to your subject, which if it's darker than the background will cause the background to over expose. You need to set the exposure to the background which then will cause your background to be properly exposed and your foreground or subject to be darker. With a point n shoot camera, accomplishing this might be a difficult task. But if you expose to the background and use the fill flash, you should then get your properly exposed image.
Jun 04, 2014 | Nikon COOLPIX S5100 Digital Camera
My Nikon D40x took white out pics on the beach
You most likely were shooting in a mode that caused your exposure to over-expose your image. Try "Auto" for starters. Once you are comfortable, learn to set "A" or "S" to control your shots as "you" want them. be sure to know how the camera is metering the shots too. All of this is explained in the manual.
Apr 27, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Shooting modes
The shooting modes are as follows: Program(P)/Auto. Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait. Suitable for taking a portrait-style photo of a person. The camera automatically sets the optimal shooting settings. Landscape + Portrait. Suitable for taking photos of both your subject and the landscape. This setting allows both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting settings. Landscape. Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting settings. Night Scene. Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting settings. If you use the flash, you can take pictures of both foreground subjects and the background. It is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Sports. Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Beach and Snow. Suitable for taking photos at the beach or on snow covered mountains; situations where there would be very bright conditions where the sun reflects off of sand or snow. Self Portrait. Enables you to take a picture of yourself while holding the camera. Point the lens toward yourself and the focus will be locked on you. The camera automatically sets the optimal shooting settings. The zoom is fixed in the wide position and cannot be changed. Movie. The movie mode enables you to take a QuickTime movie for either viewing on the LCD or on your computer. The movie will record as long as the shutter button is depressed and or until there is no storage space left on the memory in use. No sound is recorded.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Suitable for taking photos of both your subject and the landscape This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Beach and Snow Suitable for taking photos at the beach or on snow covered mountains; situations where there would be vey bright conditions where the sun reflects off of sand or snow. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the Wide position and cannot be changed. Movie The movie mode enables you to take a Quicktime movie for either viewing on the LCD or on your computer. The movie will record as long as the shutter button is depressed and or until there is no storage space left on the memory in use. No sound is recorded.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Fuji FinePix F470 Digital Camera Logo
77 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
