Question about Linksys -Cisco Wireless-G VPN Broadband Router [ WRV54G ] (107013)
Cisco linksys e1000 aoss button
Where is the aoss button on the cisco router
gymowner
  • 679 Answers
SOURCE: connectivity with my comcast cable
I have a comcast for 10 years with a cable modem and tv. The only time I ever had problems and they were major, they needed to run a new line, that's the only thing that stoped the signal from droping.Previous to that, there was an inline amp on the line, and that would have intermittent isues that you describe. Another reason may be the modem, it may be the "old" unit, tell them you need a new modem. They are going to give you a hard time because you aren't using their modem, so every time you call, they are going to ask you to disconnect the router and run through the modem.They can read the modem from their side, and if it is "on", they will stop right there. You are speaking to someone who is out of the country. I made the mistake one day of asking them if there was construction going on in my area, "because they daisy chain" the connection, and if the house next to you has the cable pulled out, it can effect you. The woman told me "she didn't see anything" so I asked her where she was because the homes on both sides werer having work done, She was in India, they outsource to Canada and India so it would be difficult to see if there was construction in Fl.They are only going to react to things that they are authorised to fix. Call them and tell them that your modem goes on and off, forget the router for now, ask for the motorola 8500 series. You may have to ask for a supervisor and don't let them talk you out of it. You also should tell them that your intermittent issue happens wheather the router is on or off, since they don't understand unless they walk you through the basic troubleshooting, which is a waste of time. You are loosing your signal because the modem is droping the connection, you can also look on the Linksys home page, and see if there is a firmware upgrade for your router, but make sure you get the right version number of the bottom.The last thing to check is to see if they have "filters" on your line, they can also cause problems with the modem. If you have a private home or condo, there is a box that stands out someware on the lawn or off to the side. Usually its not locked. Pull off the top and see if you see silver cylindrical looking tubes about 3 inches long inline with your cable line going into the box. If so they may be causing the problem. I had 3 of their trucks on my lawn at one time, and they couldn't figure out what was wrong. ten minutes after they left I had everything running. The problem is subcontractors, are doing the work and you either get a good one or a bad one, you need to keep having them come out until they get it right. So just to go over it again, Modem, Firmware on router, Wiring coming in, Filters on the line. Get to a supervisor right away or you will have to tell the story several times. Also if they do come out, ask him what his meter is telling him your signal strength is. Cable is shared and if others are using their service at high load times, that is another reason that your connection must be perfect, or this is going to be ongoing. good luck
Posted on Mar 12, 2009
router-user
  • 550 Answers
SOURCE: forgot password for wireless router
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
Posted on Jul 22, 2010
  • 170 Answers
SOURCE: CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
livingmentor
  • 143 Answers
SOURCE: I have a E1000 wireless N router and it is
Yes, you can. Just be sure the cable you connect bewteen the routers are connected on the switch side (LAN side, not internet/WAN). If you fail to do this you may run into conectivity issues between devices on the downstairs network and the ones on the upstairs network (a nework printer perhaps?). Also you should disable the DHCP Server on the second router (upstairs) as well, or else you will run into possible address issues. As well as configure each with different SSIDs and different channels (as far apart as possible, preferably 1 and 11) . Other than that your network will run fine.
Posted on Dec 05, 2010
  • 79 Answers
SOURCE: I cant find the Aoss button on my Cisco Linsys
The button you are looking for is the "Cisco Systems" logo on the left hand side.
Hold this until it turns white
Posted on Dec 17, 2010
Need to add another computer to my Linksys E1000 but lost the CD
You don't need the CD. Post the make, model of computer and the OS on it.
Dec 26, 2012 | Cisco Linksys Wirelessn Router Black...
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
How do i delete guest access on e1000 router
go to the linksys.com (it will reroute you to the cisco page) webpage and enter the number 21461 in the search box. It is an article number associated with setting up the "guest feature" it also shows how to disable it. hope this helps!
Jun 09, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Where is the aoss button located on the wireless router
AOSS (AirStation One-Touch Secure System) is a system by Buffalo Technology
Linksys should have something like SecureEasySetup (SES).
Mar 06, 2011 | Linksys -Cisco Wireless-G VPN Broadband...
I have nt been able to connect the new router HELP
Reset your router to factory, and install software from scratch... I need more details to help you more then this?
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Dec 22, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I cant find the Aoss button on my Cisco Linsys router
Dec 11, 2010 | Linksys Wireless-G WRT54GS Router...
Trying to set up wireless router on PS3 and I need to hold in the AOSS button. Where is that button?
LinkSys does not have an AOSS button. It has a CISCO button. It is on the outer edige of the router. Press and hold until it starts flashing white.
May 01, 2010 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
189 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
