Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Ewf1083 does not power up...checked power source... all ok
Machine stopped mid cycle - screen indicating remaining time froze- I turned machine off- now it wont turn back on
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
