Question about John Deere Garden
John Deere L108 lawn tractor
I am looking for the blade pulley brakes and can't seem to find them anywhere. Can anyone help with these parts.
  • Jerry Feb 17, 2012
    The parts that I am looking for is the L shaped brackets with the little brake pad on it. This is engaged (presses against the blade pulleys) when you disengage the blades. There are 2 of them on the mower deck.
  • John Deere Master
  • 2,478 Answers
You get them at http://www,greenpartstore.com Part no. GY20825
Posted on Feb 18, 2012
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
  • 138 Answers
SOURCE: where can i find a service manual for a John Deere
you can purchase a service manual from your local deere dealer or you can go to www.deere.com and go to the residential section you should be able to purchase a manual directly you will need the model number and serial number
Posted on Oct 11, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
I have a John Deere 355d lawn tractor. Every time I engage blade or release brakes the mower dies out. Checked safety seat switch and its not that.
Try pulling up on your PTO switch to engage the RIO switch. If it works then there is a problem with the reverse switch is located near the directional pedals/linkage or on the transmission. Attached is a picture of the switch from the John Deere parts catalog and a wiring diagram.
Feb 13, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Jul 19, 2013 | Husqvarna Garden
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
Blade too far forward on upper pulley
On Hobart's website (www.hobartcorp.com) I found a manual and parts breakdown of your meat saw. There doesn't seem to be an adjustment knob like on most band saws to adjust the tracking of the blade on the wheels. If you go there select the Service & Parts tab, then the Manuals & Support tab. Half way down the page select "View or download operator manuals" then look for the "Click here to go directly to the Resource Center" link. Two more pages and you'll find a model number search box. 6614 will give you the parts breakdown and manual but neither indicate a way to adjust the wheels. Most likely you have a damaged bearing or wheel shaft that's causing one or both wheels to be out of alignment enough to make the blade track as you say it does. Their website also has a "Contact Us / Dearler Directory" link where you may be able to get more assistance on how to fix your saw.
Feb 02, 2013 | Hobart 6614 Single Phase Commercial...
Garden Logo
294 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
