Question about Electrical Supplies
Crabtree 1G 2W 250W Dimmer Black Nickel
I've got this lightswitch and there is a front plate and a front one - they have come attched and I cannot work out how to seperate them, so enable me to fix into place.
All the instructions say is 'put a small screwedriver into slot and ease away'. I've tried two slots and this has simply broken the metal!
Any ideas of which slot this should be??
Ta
  • 102 Answers
Just look at the plate and you can see that it is not very thick. It will split almost in the middle of it's thickness. Take the small screw driver and slip it between them and don't be gentle just push it straight in and it will split.
Posted on Nov 03, 2008
1998 malibu dimmer switch location
when your in the car look on your left side of the steering wheel, when you do look, look for this shape on the dash board that should be the dimmer and lightswitchs2181_1.jpg
Feb 20, 2013 | 1998 Chevrolet Malibu
Which wire is the memory
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
Nov 06, 2010 | Car Audio & Video
Connecting a Superswitch touch dimmer
HI
A blast from the past "Superswitch" depending on manufacturer terminals vary but it is just a change over switch (1g 2w) with a meter check for continuety between 1 & 2 or 1 & 3.
1 was usually common (small c at side) with 2 being n/o and 3 n/c.
If you have the MK model switching is by Triac so (if you feel safe) connect your switch wires to 1 & 2 and try it .If nothing use 2 and 3,
Crabtree version had s1 s2 and com3 look closely at switch.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
Dimmer lights will not come on but the bright light works. I have change the headlights, lightswitch, dimmer switch, what esle can I check.
To keep the switch from arcing and wearing out, they use a relay. The dimmer switch turns the relay on and off, so does not use as much current. The relay is a small plastic box plugged into the fuse box, along with several other relays.
Oct 27, 2009 | 1994 Jeep Grand Cherokee
I have bought Crabtree dimmer switch but it came without wiring instructions. There are 3 terminals, one marked L1, one L2 and the other with a wavy line with an arrow across it. Which one does the 'line'...
This is a 2way dimmer the wavy line is the common so your live supply will connect to this terminal .For 2way switching your strappers go in L1 L2 if you only require 1 way switching use either for your feed out to the fitting and disregard the spare terminal.
HTH
Oct 21, 2009 | Kitchen Appliances - Others
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Need wiring digram
+Yellow...........12v battery
Sep 30, 2009 | Clarion (DB165) CD Player
I have a 2001 Focus Zx3. The dashlights, parking
Sounds like a short circuit here ? You will need to locate the short circuit . Most probable is the tail lamps and their connections , then number plate lights , then any hinged wiring going from body to a door or trunk (ie No plate illum lights) area . Sometimes the dash dimmer can be a problem . Good luck
May 08, 2009 | 2001 Ford Focus
Electrical Supplies Logo
270 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
