Question about IBM Computers & Internet
Lenovo T400 - not reading CD...
Dvd cd-rw
  • IBM Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Posted on Feb 17, 2012
  • 83 Answers
SOURCE: cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
Posted on Jul 15, 2007
SOURCE: read only cd-r not dvd
Have the same problem, it used to work and suddenly it wont do it anymore. I guess this is due to windows XP updates. Windows says that the driver is up to date and I also installed the latest firmware. I am using Nero 7 to burn. I had troubles before but somehow fixed it. Now when I insert a DVD (data) and try to open the dvd drive the whole computer hangs. The content shows for a moment before the computer freezes so it IS in the DVD.
Posted on Jan 29, 2008
  • 1019 Answers
SOURCE: Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 24, 2008
  • 236 Answers
SOURCE: dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to ka_s5@hotmail.com
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Posted on Apr 04, 2008
SOURCE: Sony DVD RW AW-Q170A Burning Problem
1. pl confirm ur drive as as sony as AW-Q170A
2. Download both file necflash_wingui.zip and 113bt_rpc1.zip
3. If ur not sure about drive being master or slave turn all the IDE to PIO mode. Pl remember flashing will not be possible if in other mode.
4. Unzip the zip file
5. Run necflash dump the firmweare file at safe location and flash the bin file with 113Bt_prc.bin.
6. Reboot in safe mode. Restore IDE to original mode.
7. Reboot and start normally. Bingo prob is solved
Posted on May 01, 2008
Tip
What is the difference between DVDRW and DVD-RW?
Simply <br /><br />cd rom = read cd 700m only <br /><br />cd rw =read cd 700m and write on it <br /><br />dvd rom =read cd 700m and dvd 4.7g only <br /><br />dvd rw= read cd 700m and dvd 4.7 gb and write on it <br /><br />dvd compo= read cd 700m and write on it and read only dvd 4.7 not write <br /><br /><br />best regardes
on Apr 02, 2011 | Computers & Internet
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
My lenovo 3000 n100 is not reading a sony dvd-rw.although the cd is inside the computer,it is still showing enter a disk
It sounds like you need to replace your drive. If you've tried multiple cd/dvd's you probably need to replace the drive.
Jan 04, 2011 | Lenovo 3000 N100 DVD-RW / CD-RW Drive...
I have a t400 lenovo and I can't seem to hear any sound or be able to adjust the sound or mut. I could at one time, but now nothing
goto control panel > device manager > sound and audio devices and check for the device status.... if its not working properly the you need to reinstall the driver, this will fix the issue.... or please make sure that did you removed any windows components from add/remove programs.... if so, then do that again and enable all windows components, in that case it may ask you to insert the windows cd/dvd in the cd/dvd drive.....
Apr 19, 2010 | Lenovo ThinkPad T400 - Intel Centrino 2...
Not able to read dvd's and able to read cd's model lenovo 510i
While I was not able to find that specific model of laptop, I was able to locate the CDRW Bay and based on my research this bay only supports the following models. Though it may look the same and even have the same interface, if it is not in the supported model list, it will not properly function.
Supported Media Types:
  • CD-ROM
  • CD-R
  • CD-RW
  • DVD-ROM
Compatible with:
  • IBM Lenovo ThinkPad R50
  • IBM Lenovo ThinkPad R50e
  • IBM Lenovo ThinkPad R50p
  • IBM Lenovo ThinkPad R51
  • IBM Lenovo ThinkPad R51e
  • IBM Lenovo ThinkPad R52
  • IBM Lenovo ThinkPad T40
  • IBM Lenovo ThinkPad T40p
  • IBM Lenovo ThinkPad T41
  • IBM Lenovo ThinkPad T41p
  • IBM Lenovo ThinkPad T42
  • IBM Lenovo ThinkPad T42p
  • IBM Lenovo ThinkPad T43
  • IBM Lenovo ThinkPad T43p
  • IBM Lenovo ThinkPad T60
  • IBM Lenovo ThinkPad T60p
  • IBM Lenovo ThinkPad X40 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad X41 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad T30, X30, X31, R40 series (2366, 2367, 2884, 2885, 2681, 2682, 2683, 2896, 2722, 2723, 2724, 2897, 2672, 2673 - when installed with the optional ThinkPad Slim Drive adapter for the UltraBay 2000 or X series UltraBase or Media Slice)
If you see your model in this list comment back and we can move forward with getting your issue resolved.
Good Luck,
NOLA Tech
Jan 29, 2010 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
I want new laptop to write CDs - spec says DVD-ROM
http://reviews.cnet.com/laptops/lenovo-thinkpad-t41-2379/4507-3121_7-30567436.html
Thats the spec for yout laptop, if you have the plug-on module then you can write on it.
Optical Storage
  • Type CD-RW / DVD-ROM combo - Plug-in module
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 16x
  • CD / DVD rewrite speed 10x
Good luck
Nic
Apr 27, 2009 | IBM ThinkPad T41 Notebook
Computers & Internet Logo
311 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
