Question about Exercise & Fitness
How do i troubleshoot an LRC3002 REmote Trainer?
What is a adjective
That is a weird question under PC Desktops.
This is English Grammar
An adjective is a describing word, usually about a noun.
'That is a trainer' - trainer is a Noun
That is a new trainer' new is an adjective describing the noun trainer.
OK?
Mar 04, 2014 | Computers & Internet
HOW TO USE TRAINER IN PRINCE OF PERSIA WORRIER WITHIN
First play the trainer of prince of persia then play game.Press hot keys of trainer.Then work your trainer.
  • eg of hot keys is F2 F3 F4 F5
Mar 22, 2012 | Ubi Soft Prince of Persia: Warrior Within...
Hi I have Halo1 (combat evolved) for pc. I play single player only. I have finished the game on legendary (only just!) Would now like to play through again with unlimited ammo. Have version 1.09....
Click the link to download Trainer 1.04, if 1.xx does not work try more trainers below there is a specific trainer for a specific version. some times the trainer might work but the game crashes, if that happens try to enable cheats one at a time.
1. Unzip/Unrar trainer into your game directory, then start trainer
2. with "pztrain.exe", and finally start the game.
3. Toggle trainer options by pressing the following key combinations: to disable press the same key.
Enable Disable Option 1 Infinite 'MEGA' Shield 2 Infinite 'MEGA' Health 3 Infinite Ammo/Grenades 4 Infinite Flashlight 0 Resume All Back To Normal
Click the link to download Trainer 1.02. Same procedure above..
Click this link to download Trainer 1.00
2. with "trainer.exe", and finally start the game.
1 - Infinite Health + Energy 2 - Infinite Ammo (all weapons and nades) 3 - No Weapon Overheating 4 - Infinite Flashlight 5 - Invisibility 6 - Instant Kill Ammo 7 - Vertical Limits Ammo 8 - Chaos Sight On 9 - Chaos Sight Off K - Freeze Universe on L - Freeze Universe off
Thank you for using FixYa.
Hopefully this trainers helps.
Jul 29, 2011 | Computers & Internet
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
Cycleops 2 Trainer: trainer is leaking oil...
Crank seal is away. Mine went and i had to strip the fluid2 trainer to replace it. They have a lifetime warranty so they will replace it for you.
May 16, 2010 | Fluid Cycleops 2 Trainer
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Nov 29, 2009 | Proform Quick Burn Pro Treadmill with 12...
Instruction manual for olympus cross trainer
I cannot get the timer to work on the olympus sport ascent cross trainer.
Jun 28, 2009 | Exercise & Fitness
Problems setting up bike trainer
put the bike in while the trainer is opened. tighten the bolts around the skewer. that should be straight forward... good luck
Jan 08, 2009 | F2 Forza F-2 Magnetic Bicycle Trainer Bike
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
