Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
My Dishwasher is not working, no power on control panel.
My Dishwasher "Whirlpool Quiet Partner II" is not working, no power to the control panel. I have verified that there is power getting to it from the wall, I have removed the thermal fused and verified it had continuity. What should I check next?
3 Suggested Answers
SOURCE: Whirlpool Quiet Partner II
Thank you so much!!! heated dry & hi temp buttons worked!!
Posted on Feb 13, 2008
Take the back of the door off and remove the panel where all the wires lead to. If you look at the handle that holds the door shut there are 4 wires on a connector there on its switch. There should be a brown one. Follow that wire back and about 12 inches later there is a little switch it connects to. That switch is your problem. Remove both wires connecting to it, splice the 2 wires together and your dishwasher should work fine until you get the actual replacement part. If not you can just leave the wires spliced and it will still work fine. Hope this helps.
Posted on May 30, 2009
How do you reset the control panel on a whirlpool quiet partner II dishwasher?
It should reset automatically. There could be lint buildup inside the dryer airflow inlet that is located just inside the door on the bottom. There could be lint buildup at the exhaust vent at the back on the bottom of the dryer.
Nov 09, 2015 | Whirlpool Dryers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
My whirlpool quiet partner II dishwasher stopped working no power...i just used it and went to do another load and no power. I checked the outlet and there is power. what part could be the cause of...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner 2 dishwasher from Lowe's model DV 1055XTVS. The "clean" light flashes three times in a row over and over and the "lock" light is one. None of the...
I have a whirlpool quiet partner 2, its brand new. It leaves a filmy residue on my plastic ware. I use the finish detergent as well as the rinse and no luck. Whats the problem.????????
Nov 09, 2010 | Dishwashers
I have a whirlpool quiet partner II dishwasher. Can the front panel be removed and changed to a differemt color.
check out applianceart.com they have many options to change colors, designs and even stainless steel panels and covers.
Apr 08, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Quiet partner ii just stopped
Most likely it has an internal fuse or relay gone bad. Check the curcuit w/ a "glow stick" power identifier available at Lowes or Home Depot.
Aug 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
115 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
