Question about Delphi Roady SA10035 XM Radio Receiver
Won't power up
The unit does not power up. nothing. I'm not sure if there is an internal battery, or perhaps it's the remote battery. unit has been well taken care of, but has not been used in about four months. thanks
0 characters
1 Points
Remote control won't turn on radio
Have been to the audiovox home Page type in your model number and go to trouble shooting there you will find how to program the remote back to factory settings
Nov 16, 2012 | Audiovox Xpress R XM Satellite Radio...
Won't power on
Have you tried plutting it in directly to the power source with out the battery? If this works, it may be that the battery is dead, you can try to jump it by putting the battery in after it has already been turned on. Or just replace the battery:
If it does not power on, it could be the power cord is bad:
Otherwise, the unit itself may just be dead.
Jun 26, 2012 | Pioneer GEX-INNO1 XM Radio Receiver with...
I just purchased a new remote for my Delphi XMXpressRC. The remote won't operate any functions. My old remote still works but is worn out. Does the new one need to be programmed?
There is no programing necessary for the remote. Are you sure you have the correct remote? It should be this one:
Does the remote you have operate anything on the receiver? If not, I would check the battery. (Maybe try swapping batteries with the old one to see if that makes a difference)
Jun 07, 2011 | Delphi XpressRC XM Satellite Radio...
Delph Skfi3 won't power up now matter what docking station it is plugged into. Is the internal battery accessable?
No, internal battery is NOT accessible. Leave it plugged for about 4 hours until it says "battery charging" and then 'battery charged' on the display. THEN give it a try to power up by holding down the power button for about 2 seconds. Let me know if this works for you.
Dec 31, 2010 | Delphi SKYFi3 XM Radio Receiver
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My unit will not power on either on the dock or with the power cable plugged straight in and I know that my electrical outlet works
mine has some funny problems including this one. However when I do the power reset, it then turns on. To do this, hold down the power and Vol Up buttons for ~3 seconds and it should reboot. I don't know for sure, but I think it has an internal power management system (which most gadgets with Li-Ion batteries do), and just like my mac sometimes it gets confused and needs reseting.
Nov 06, 2009 | Delphi SKYFi3 XM Radio Receiver
Pioneer GEX-XMP3 stuck in the power up mode
Just off the phone with Pioneer customer service. Apparently a "software glitch" common enough that an internal memo has gone out to replace units under warranty without further trouble shooting. The last step in the process was to remove the battery, place in the original charging cradle without the battery, and hold the power switch down for 10-15 seconds; if the "Please wait" message continues, the unit is defective.
Feb 23, 2009 | Pioneer AirWave XM2Go Satellite Radio...
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Home Satellite Radios
No power from transformer
I had the same thing happen on my original Roady2. I suspect the powerplug port on the Roady2 unit is not getting a good connection. Does the transformer plug have a plastic tip? You can try to cut that off with a sharp razor blade. Sometimes that will make a good tight connection. What I did was buy a used Roady2 unit on ebay. Also another cause is
the power connection is not being made by an internal problem or wear caused by constantly plugging and unplugging the power port. I use a Cambridge XM playdock boombox at home. I bet getting a different unit will solve the problem. The only problem is that finding a used unit might take some work. Good Luck
Oct 27, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Delphi Roady SA10035 XM Radio Receiver Logo
Top Delphi Home Satellite Radios Experts
xxxxxx xxx
Are you a Delphi Home Satellite Radio Expert? Answer questions, earn points and help others
