Question about Hotpoint Ovens
Hotpoint ew82 main oven not heating uo
Have tried manual operation but still not working, light and fan ok
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
barkencoa
  • 3463 Answers
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
barkencoa
  • 3463 Answers
SOURCE: My oven wont heat up light and fan work I have
Even though the element look's o/k, it is more than likely faulty, more so if the fan is working o/k.
The only 100% test to make sure if it is faulty, is to test it with a meter.
In my experience I would advise you to replace the element.
Thanks.
Posted on Nov 03, 2009
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Hotpoint bu 82, main fan oven not heating but the temp light and fan are ok just no heat. what would be the most likely cause, and how can i repair thanks
It is going to be the fan oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
This is a very easy repair to do.
Mar 17, 2010 | Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Oven not working
Thanks.
Jul 21, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Ovens Logo
131 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
