Question about Nikon S8100 Digital Camera
Nikon s8100 focuses only in center and rest has a
Hi, does anyone know how can a fix a focus problem in a Nikon S8100: it focuses only in center and rest of image around the center has a "zoom-in" like blur. This in every shooting mode. Please help
  • 734 Answers
You need to replace the lens assembly. Aspherical lens needs precise placement of all elements.
Posted on Feb 16, 2012
  • 102366 Answers
SOURCE: I have a nikon d60 and it wii not focus when you
Try using the diopter control just to the right of the viewfinder. Carefully slide it up or down while peering through the viewfinder. Don't poke yourself in the eye while doing this.
Posted on Jan 19, 2010
dj_relly999
  • 4070 Answers
SOURCE: Nikon S8100. Lens won't go
Hi and welcome to Fixya!
As a first course of action I strongly suggest that you remove the battery of the camera. Let it sit for atleast 5mins. then insert the battery. Turn the camera on and observe how it goes, this should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one and happy holidays!
Posted on Dec 25, 2010
  • 147 Answers
SOURCE: lens error. lens is
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
19messiah65
  • 230 Answers
SOURCE: my nikon s8100 won't turn
It means it has a bad battery since it recognizes power using a different power source. Replace the battery and it should work fine.
Posted on May 10, 2011
  • 102366 Answers
SOURCE: I have a Nikon D3100
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
Posted on May 22, 2011
Testimonial: "Thanks, very helpful information!"
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
Canon S8100 battery won't charge
well somethings wrong with your canon S8100 battery or you need a new charger, or battery
Apr 24, 2012 | Nikon S8100 Digital Camera
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
How do I fix my Nikon COOLPIX S8100 flash
Check the camers's flash setting, make sure the flash has not been turned off.
Also check the batteries, make sure they are fully charged, a low charged battery will not charge up the flash capacitors.
Nov 17, 2011 | Cameras
Nikon s8100 lens error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 09, 2011 | Nikon S8100 Digital Camera
S8100 won't turn on after being dropped.
Sounds pretty straight forward. The impact most likely damaged the camera. Take it in to a service center to be checked out.
Mar 18, 2011 | Nikon S8100 Digital Camera
How can I stamp date on pictures using Nikon CoolPix S8100 camera
Press the MENU button. Select Setup (the wrench icon). Select "Date Imprint".
Dec 10, 2010 | Nikon S8100 Digital Camera
Nikon S8100 Digital Camera Logo
98 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
