Question about Bosch Refrigerators
Bosch KSV fridge freezer manual
Freezer is +0 oC in cold house. What is role of Ambient temperature switch. Where can i download the manual?
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: F&P Fridge freezer N395BH cycle time
Most any refrigerator will run 75% of the time and off 25%.
Posted on Feb 28, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
SOURCE: Fridge is warm, freezer works.
Smilar problem, but the model is GTH15BBMFLWW
Posted on Aug 20, 2009
Hi ive hoover hrfa54w fridge freezer just over a year old. Ive noticed freezer is starting to defrost sometimes the freeze again....its in a holiday cottage so often in a very cold ambient temperatur
Ambient temp will cause the thermostat some confusion. There's probably nothing wrong with the fridge, my freezer doesn't like being in the outhouse. Only alternative is only switch on when you are there or move it to a cupboard where you could put a low output source of heat just enough to keep it happy. Then get it out when you are there?
Jan 25, 2015 | Hoover Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
My frig is not cold enough
Maybe the room you store it in is to hot as the fridge will only cool a certain amount of degree's below the ambient temperature, if it has a freezer compartment make sure it is regulary deforsted as the fridge temperature is linked to the freezer temperature.
Regards
chris
Jan 15, 2010 | KitchenAid Refrigerators
We recently moved to a house with a Bosch KGV28V01GB fridge freezer outside but it doesn't seem to be working. Its plugged in and the light comes on when the door is opened. The switch is set to ON but...
Good day,
Refrigerators are designed for indoor use only. The lowest temperature they will perform normally is 55 degrees.
As the temperature drops below that it degades to the point of not working at all.
P.S. If you move it inside, give it a 24 hour warm up period. The oil in the compressor will be too thick, and can even ruin itself trying.
Jan 01, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer cold but fridge warm
Hi and welcome to FixYa,
Initially, a couple of possibilities you may want to check, consider, try:
  • evaporator fan - purpose is to draw cold air from the freezer and blow it to the refrigerator section. This is actually what cools the fridge side. A test is to open the door, press and hold on the door switch, light should go out, fan should come on after a minute or so. If not, possibly a defective fan (most likely) or faulty controller (least likely);
  • thermostat - this is both a sensor and a switch. It sets the coldness level of the fridge area. Once it senses that the fridge temperature is relatively high, then it triggers the controller to engage the compressor and kick in the evaporator fan. A continuity where its resistance would change depending on the ambient temperature;
  • controller board (a possibility) - as the name implies, it controls the functions of most (if not all) of the active components of the refrigerator/freezer. It receives input from the different sensors and reacts accordingly by switching other components on/off.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
New Fridge/Freezer placed in Garage,when ambient temp falls freezer stops working
You do not say what type of Fridge/Freezer it is. Some types will not work in cold ambient temperatures, ie unheated garages.
Check the user instructions, if it does not say anything about this, get onto the service department for advice.
Dec 08, 2008 | Refrigerators
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Refrigerators Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
