Question about Denon DN-2600F CD Player
I have an denon 2600F dual dj player and is not reading the cd also door open slow
Is not working properly is not reading cd and the cd tarys are slow at closing
4 Suggested Answers
DiMiS
  • 11 Answers
SOURCE: having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Posted on Aug 10, 2007
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Posted on Oct 14, 2009
  • 794 Answers
SOURCE: My Denon DCM-380 CD player
Hi owsfmiller,
This Err that appears on your CD player is caused by a CD stuck inside the tray. It's most likely that the CDs came off the trays and got stuck inside. Open the chassis of the player using a screw driver. Then, manually turn the driving gear of the CD tray to free the stucked tray. Be careful so the setting of the tray and the laser eye is not change. This should resolve the issues you're getting.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 16, 2011
Replace laser unit
Try to make it right. Check this link for more details.
Sep 03, 2012 | Denon DN-2600F CD Player
My jog wheel on denon dn s1000 is messsing up will not work properly
The encoder probably has dirt or dust in the pickup. Remove the wheel and clean the sensor area.
Aug 05, 2011 | Denon DN S1000 Scratch DJ Table Top DJ CD...
When ejecting a cd the housing would open and close right back sometimes. How can this problem be fixed?
It sounds like the open switch inside the door is dirty & cannot make a connection when the CD door opens. Clean the switch & it should function properly. Otherwise, replace that switch.
Jan 08, 2011 | Denon DCD-3000 CD Player
Control unit not working. main unit is powering up but, controller not receiving any power.
I'd suggest replacing the patch cord from the player to the controller.
Oct 12, 2009 | Denon DN-2600F CD Player
HI HOW DO YOU CLEAN THE DENON DN-S5000
Let me start out by saying what not to use: Don't use the cleaning CDs that you can buy. Most of those have tiny brushes on them that could scratch the optics inside your CD player and make things worse. Your Denon CD player and similar pro grade DJ CD decks are a higher precision player than the average consumer CD player that those things are marketed towards.
Your solutions are these:
  1. Find a vacuum cleaner with decent suction and use the hose attachment remove any dust or other debris that may be lodged inside the player by running the hose around the entire player (you'd be surprised where dust can lodge (and from where it can be dislodged).
  2. You can use canned air... but two caveats: Canned air doesn't necessarily move the debris and occasionally when spraying it, you get bursts of moisture with the air. Obviously moisture inside your playe would be a bad thing.
  3. Take your player to a reputable electronics repair facility and have it professionally cleaned and the optics adjusted.
I keep a microfibre cloth with me in the DJ booth and look at every CD before I put it inside my players (I have DN-S3500s) and if there's any grime, I use the cloth to remove it.
Dec 21, 2008 | Denon Dns1000 Table Top CD Player CD...
READING CD'S
well maybe it needs to change the optical lens now. but try to adjust the variable resistor at the optical lens. I don't know if its turn to left or right.
Feb 07, 2008 | Denon DN-2600F CD Player
CD Tray on one side doesn't open.
I have also had the sticking CD Tray problem with my Stanton. I disconnected the until and unplugged the separate read out control panel. I was going to strip it down, but when I plugged the power supply on it worked fine again!!!!. I wwill reconnect and see what happens!!
Dec 14, 2007 | Stanton C.501 Dual MP3 CD Player
Dual cd player
one side of my denon 2600f cd player will not read a disk. What can I do
Aug 31, 2007 | Denon DN-2600F CD Player
133 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
