Question about Seagate 1TB FreeAgent USB 2.0 External Hard Drive
How to write to a seagate hard drive from a mac
    Master:
  • 451 Answers
You will need to reformat the seagate drive if it has not been formatted for mac.to do this.
connect your seagate drive to the mac.go to spotlight the magify glass at the top right corner and type in disk utility and select disk utility
in disk utility make sure you select the seagate hard drive and choose erase. at the middle of the screen look for format and choose mac os extended. click erase.
you should now be able to write files to your seagate drive.
also if you would like be able to transfer files to and from a mac or PC then you will need to format the drive as FAT.
Posted on Feb 16, 2012
Alcatrazx
  • 65 Answers
SOURCE: Seagate Free Agent Drive Cannot be Modified on Mac G5
First of all Hello John :)
The new seagate drive you got needs to be unpartitioned and its file format system needs to be deleted and changed.
NB: You will lose all your data so make sure that you copy everything useful off it before you do these steps.
1. Get hold of a windows PC and right click on my computer
2. Choose manage ... choose disk management right click on the drive and delete the partition type
3. delete again until it comes unpartitioned space
4. Then go to your mac and you should be able to format it as a regular Mac drive.
5. If the Windows PC is inaccessible. Get hold of a copy of Linux UBUNTU distro. Boot your MAC from CD choose to boot os from CD (don't worry it will install nothring on your MAC it will just use the CD but make sure you choose the right option)
6. Keep your hard drive attached so it gets detected during bootup. Once the UBUNTU OS boots choose GParted and from there do the same thing i explained above.
Hope that this was of help :)
Cheers
(please take some time to rate solution)
Posted on Jan 07, 2009
damien729
  • 221 Answers
SOURCE: seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Posted on May 30, 2009
bob_computer
  • 3153 Answers
SOURCE: my mac does not recognize my seagate hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
If the drive makes any kind of clicking pinging noises it may well be beyonde repair. This is known as "the click of death"
Posted on Aug 27, 2009
  • 54 Answers
SOURCE: Mac Formatted Seagate Go 250GB Hard Drives are nearly $40 extra..
Yes, you can format a windows OS drive on your MAC to one of the MAC filing system, which would work just as good.
Posted on Jan 20, 2010
  • 95 Answers
SOURCE: My seagate hard drive cannot be detected on the
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Posted on Apr 05, 2010
I just bought a Seagate 2 TB desktop drive for Mac and PC, it works on my PC but nothing happens on the MacBook
If the Seagate hard drive has been formatted on a PC in NTFS then the MAC cannot read and write to this hard drive.
To exchange data between the PC and MAC then the Seagate hard drive needs to be formatted on a PC in FAT32 not NTFS.
Dec 12, 2012 | Seagate FreeAgent GoFlex Desk 2 TB USB 20...
How do I get everything from my external hard drive onto my Mac and then completely clear the ehd?
The problem you really face is a lack of space on the Mac. The movement of files from the Seagate to the Mac is easy. Plug in the drive and open it, then select the items you want to transfer from the Seagate and drag them to the location on the Mac where you want to store them. Job Done. When the files have all been transferred you just need to "Format" the external drive.
May 09, 2012 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have purchased a Seagate free agent Goflex 500gb I want to run it with my Mac Pro note book it dose not work
For a MAC to use an external Hard drive, the hard drive has to be formatted FAT32 file system. That is the only file system MAC sees.
Jun 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Seagate External 500g hardrive and I need to down load the mac driver. My computer is a Mac Book Pro 15". Can you tell me how to do this? It says on box to go to www.seagate.com but I can seem...
I called apple about this and they said there is no mac driver, that a mac should read a seagate external hard drive without any driver. My file system was ntfs.
Sep 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Im trying to copy from mac to pc using seagate removable hard drive and its not working? When i plug the Seagate into my PC nothing happens
The hard drive volume format is only for MAC. Check the volume format if it is MAC OS Extended or MAC OS Extended (Journaled). If it is, then change it to MS DOS to make it readable and writable to a PC and MAC OS
Jul 08, 2009 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Read only on a mac
http://www.seagate.com/staticfiles/support/downloads/firmware http://atulchitnis.net/files/seagate.pdf
Apr 18, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Jan 24, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate 1TB FreeAgent USB 2.0 External Hard Drive Logo
119 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
