Question about RCA 6' Video/Optical Combo Cable -- DT6VHP
Tv wil not change channels unless vcr is on
The power went off and back on early one morning. Now the tv will display the channel number on the screen but will not change channels. You must turn on the vcr in order to change channels. I took the batteries out for 12 hours and also held the number 1 down for over 60 seconds to drain the micropocessor. I have unpluged the tv, receiver, and vcr for over 12 hours. I have tried everything on the remote and even the controls on the tv does not work.
    President:
  • 3,130 Answers
You must go into the menu, go to the channel setup and do a channel scan.. Your TV simply lost the channel memory. Good Luck
Posted on Aug 16, 2006
SOURCE:
How do i record from tv to vcr and play back
Leon, I believe models that are able to do this have a built in tuner, so that means cable would go into VCR/DVD player/recorder then to TV.
Your TV would be set on Channel 3 or 4 and the VCR/DVD would then be used to change channels and also allow recording of program.
Feb 20, 2016 | Televison & Video
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Do I need to throw out my GoVideo because it is not digital. Comcast recently went all digital and I cannot get any response on my VCR. Channel 3's view stays consistance from the TV Channel and doesn't...
Not if the unit itself still works; that is, it still plays videotapes and DVDs (with picture and sound).
Check your TV, you may have the wrong input selected for your unit (and/or other connected devices), or the TV is on the wrong channel; hence why you can't see anything from the VCR.
As for the ComCast box, give them a call and ask about it - quote the box number, and ask if it is digital or analogue - if it is the latter, they should replace the box free of charge as part of your cable subscription.
You do not need a new combo unit, unless you want one later which has a digital tuner. All it means is that you have no analogue TV channels in your combo unit.
Apr 04, 2011 | GoVideo DVR4200 DVD Player/VCR
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Tv will not change channels
Unplug unit from the wall for several hours and try again
Aug 23, 2006 | RCA 6' Video/Optical Combo Cable -- DT6VHP
Televison & Video Logo
137 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
