Question about Cameras
Where can I obtain a Horvex 3 Metrawatt A.G. light exposure meter, manual?
5 Suggested Answers
  • 60 Answers
SOURCE: Inconsistant exposure in Manual mode
In manual mode the light meter result is the output of setting the apeture and shutter speed. It will constantly change as you change these and the ISO until you get the desired exposure. Is this what you mean by inconsistent? If it is giving verying results in the same conditions try it with ISO 100. That should fix it
Posted on Aug 05, 2009
SOURCE: Our camera (S9500) has mysteriously stopped
Yes. contact Fuji and it cost about £14.00, its a doddle to fit.
When you recieve it you'll work out how to remove the broken part because you'll understand how it locates, basically a small Pozi screwdriver and a sharp knife to lever the top off.
Contact Fuji 'placeanorder@fuji.co.uk'
Posted on Feb 02, 2010
  • 11967 Answers
SOURCE: Camera and light meter confusion
Why are you using a light meter with a point-and-shoot camera?
Posted on Jul 30, 2010
Testimonial: "You have helped so much. I'll be back with more questions. But hopefully I can figure out most it now."
  • 11967 Answers
SOURCE: I have a Canon Rebel
The blinking light may be telling you the picture you want is out of the camera's range. You may have to increase the ISO, shoot at a slower shutter speed, or open the lens aperture.
Posted on Aug 24, 2010
Bought cheap extention tubes, now camera wont recognize the lens. How do I use them
Set the exposure mode to "M" (Manual). You'll have to set both the aperture and shutter speed yourself.
You'll also get no exposure assistance from the camera's light meter. You can review the picture after taking one and/or use the histogram to tune the exposure.
Sep 30, 2013 | Nikon D5000 Digital Camera
Noed help to USe Vivitar 650 - 1300
You have to use the Manual exposure mode (turn the mode dial to M). You get no help from the camera's light meter.
You can meter the scene with a separate light meter, or put a different lens on the D90 to get an approximate exposure. Take the shot, look at it on the LCD screen, and adjust.
May 27, 2012 | Vivitar 650-1300 Manual Focus T-Mount...
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
I have a Nikon FM film camera. The viewfinder has three exposure indicators visible within the viewfield: + for overexposure, O for correct exposure and - for underexposure. These indicators have...
If the red light is steady on the minus sign even if you vary shutter and aperture settings and point the camera at different light exposures, then this is a metering problem. If the red light on the minus sign turns off when you have correct or over exposure, then it would mean your indicator lights for o and + are busted. Have your metering checked by a competent camera technician. In any case, since your camera is fully manual, you can use the 'sunny 16' rule and still shoot away.
Feb 26, 2011 | Nikon Photography
I have a Canon Rebel XSi. I'm trying to shoot a photo of my sleeping 2 year old, so the light is obviously low. I have the cameral on manual mode. I used the light meter to obtain my exposure, but when I...
Aug 24, 2010 | Canon EOS Rebel XSi Digital Camera
Jul 29, 2010 | Pentax Optio S5z Digital Camera
Aug 04, 2009 | Canon EOS 40D mit 18-55mm / 55-250mm...
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Useing a weston master2 exposure metre
They're lovely old light meters and there's an online copy of the manual for your exact model at the address below:-
http://www.urmonas.net/manuals/westonII/westonII-1.jpg
Have fun, and please return the favour by rating my answer.
Apr 20, 2009 | Cameras
Cameras Logo
145 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
