Question about LG DLE7177 Dryer
GE PROFILE DRYER DPXR473EW0WW HEAT/TIMING ISSUE
My dryer wont heat on the Timed or EasyCare dial settings. It will only work at one point on the Cotton setting.
Also, the timing knob doesn't advance unless I use the Timed setting (but then with no heat). So the dryer just keeps running until I open the door.
Think it's the timer control or heat sensor?
Help!
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
GE profile dryer model # DPXR473EW0WW wont turn off on auto mode. It will turn off when on timed dry mode and if there are no clothes in it.
A faulty timer will cause the condition you described
Sounds like you have a timer malfunction and will have to be replaced because timers cannot be repaired.
Be sure to replace with the same brand/type to keep the wiring correct. Otherwise the wiring will not be the same, and you will have to follow the timer instructions on replacing the wiring in the box with the timer.
If replacing the time I HIGHLY RECOMMEND that you only remove one wire at a time, and then place that wire on the new timer. No mistakes that way.
This is a FREE answer...Please Rate Me
Sep 26, 2010 | GE Dryers
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
Mar 06, 2010 | GE Dryers
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Electric Dryer Low Heat Problem
You may want to remove the back of the dryer to see if all of the element is glowing. Sometimes the element opens and then welds itself to the metal case, which would cause a partial, but not total loss of heat (slower drying time). If that is the case, part of the element will be glowing, and part of it will not.
Jan 25, 2009 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
LG DLE7177 Dryer Logo
371 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
