Question about Brother P-Touch 2600 Thermal Label Printer
How do I change the font size on a p-touch 2600 label maker
5 Suggested Answers
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
Jimsta01
  • 405 Answers
SOURCE: how do i change the font size on my label maker?
Please follow the link below for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000247/pt1180ug01caen.pdf
Posted on Mar 30, 2010
d-ruffles
  • 65 Answers
SOURCE: How do I change the font size on my lavel maker
If you go into the menu, and you go down to font, hit enter. It should bring up size, style etc. If not, please tell me.
Posted on May 11, 2010
WonderTech
  • 268 Answers
SOURCE: brother p-touch model 1880 label
To change the font size, do the following:
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
* SIZE1 equals Standard Size.
* SIZE2 equals Double Width.
* SIZE3 equals Double Height.
* SIZE4 equals Double Width & Double Height.
* SIZE5 equals 4 x Width & Double Height.
* AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Posted on Aug 09, 2010
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Brother p-touch model 1880 label maker- how do you change the font size
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
I have a LabelMaker 450D and I do not know how to make the font a smaller size. I want to print a label that has a name in a larger size and a line underneath with the job title that is in a smaller size...
Hello. Here is a free downloadable manual for your labelmaker. http://www.dymo.com/media/UserGuides/LM450D_US_931764.pdf
Turn to pages 9-12 to learn how to change fonts and how to do multiple fonts and underlining all at once.
The label maker remembers the last feature
selection made so that each time you enter one of the
feature menus described in this section, you are
positioned at the last item selected from that menu. J.
Aug 07, 2010 | Office Equipment & Supplies
May 11, 2010 | Brother P-Touch 1180 Label Printer
How do i change the font size on my label maker?
Mar 17, 2010 | Brother P-Touch 1180 Label Printer
CHANGE FONT
The printer can be stuck in double line mode, although it indicates that it is single line mode. Switch between the two modes, pressing " enter" and " clear ", until you are in single line mode again. Now you can change text size again.
Jun 03, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Can't change the font style & size on my Brother PT-65 Label make
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT 65 Label Maker
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Dec 31, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-Touch 2600 Thermal Label Printer Logo
858 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
