Question about TORK Hardware & Accessories
How do i put my tork ss700z timer in auto mode
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
Hello, I have a Tork K600Z astronomic timer which has 6 sets of contacts off of a relay for each. We've burned out the first two releys since the original installation about 7-8 years ago. We've tried to...
Sounds like you need to reprogram timer ....
K series is a multi-channel timer.
If you have 4 relays, then you have 4 channels, and each must be programmed separately.
6 relays, 6 channels.
Each channel controls one of the relays. This lets the timer control multiple circuits such as lights etc, each with a different programming schedule.
Each relay has 3 wiring terminals that are dry until wired with voltage.
Following links has manuals and resources:
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#K-series
Intermatic makes a similar series of multi-channel timers, with 1-2-8-16 channel models:
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET70000
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2017 | Hardware & Accessories
I need instructions on how to set the timers on my tork electric timer for my outdoor lights ,it is put into my switch inside
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do you set on and off mode???
Tork, GE, Woods, Intermatic make a series of timers that have pins
The pins push out for OFF or ON times depending on brand
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
I have a Tork timer model number 1101 24 hr time switch. Can you tell me how to set it???
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Oct 14, 2010 | TORK 651A Photocell Controlled Mechanical...
We have 2 DZS400 digital tork timers. unfortumately when DST days were changed we have not been able to use the automated dst transition and must manually change the clocks twice each year. is there a way...
DZS400 product descriptor shows DST, and many other programming options:
1) This might help or not:
You can modify DST start & end times > Press MODE until dSt shows > Press MONTH, DATE, DAY to modify start times, and then press ENTER. (or press DEL and ENTER to delete) > Press MONTH, DAY, DATE to modify end times, and the press ENTER > press MODE to return to AUTO.
2) According to DZS400 product descriptor "The controller has 365 day holiday capabilities with 24 single dates" ... if above solution doesn't work, the 24 single dates might provide enough days to fill in programming gaps in the DST. Your manual should have programming steps.
Sep 18, 2010 | TORK Hardware & Accessories
HOW DO I INSTALL A TORK SS720A TO A THREE WAY SWITCH
The Tork SS720A's can only be used to replace a single pole switch. For 3-way switches you need the Tork SS700 or similar device like any of the SS700Z series.
http://www.electriciansupplies.com/product.cfm/p/123028/Tork-SS700.htm
Mar 02, 2010 | TORK Hardware & Accessories
Hardware & Accessories Logo
94 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
