Question about Worldtech Devices Toys
I have a heli zx35090 i ned blades for and cannot find
Ordered this from hobby tron they said they didnot have parts cannot find anywhere
My s33 2.4g flying only 1-2-3 feet from the grownd pls help me pls...
if the rotors have been damaged then the turbulence from that damage is probably slowing the rotation speed down and the electric motor is not powerful enough to get it any higher
file any burrs off or get replacement blades
Jun 20, 2016 | Syma s33 3 channel rc helicopter 2.4ghz...
Syma S107 Heli quit in the middle of flight.
Most likely to be a faulty PCB circuit board.
We have all spares available on our website.
Kind regards, Julian.
rccontrolfreak.co.uk
Dec 09, 2012 | SYMA Toys industrial New Syma S107 Radio...
9053 bottom blades
Have the same problem with my S107 heli. I determined it's in the speed control hooked to the gyro control. This control feature helps keep heli
from turning in flight caused from tork. The lower blades are the ones
that speed up slow down to keep heli orientated. I'm replacing the control board.
Dec 16, 2011 | xheli 9053 Outdoor Volitation Metal...
My S107 does not hover very well. It moves in a large circle on its own. It isn't the trim as it doesn't spin around the axis of the rotor. It points in the same direction but slowly moves left, back,...
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Jan 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My syma s 107 copter transmitter dont connect5 to helis.controller light blinks
Try setting the heli down on a table and with the transmitter behind the heli, turn the throttle up until the blades start spinning. If that doesn't work, then I don't know how to help you.
Oct 03, 2010 | SYMA Toys industrial New Syma S107 Radio...
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
Havoc heli flight problems
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Jan 05, 2009 | Air Hogs Havoc Heli Helicopters
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Main Rotor Blade - spare part
This website sells them: www.kcsupermall.com
Look under 2-Channel Helicopters and find the Double Horse 9086, click on it for more details.
The parts are at the bottom of the page.
I bought a set (2 bottom & 2 Top) recently for $15.00. They ship via USPS First Class mail so the shipping is only about $3.00.
Dec 16, 2008 | Axial Syma 9086 Helicopter
Part needed
Call Hamilton beach at 1-800-851-8900 you can order the part. I just ordered two of them for $12.96, tax & shipping included. Spent WAY TOO MUCH time looking for it on the internet
Sep 19, 2008 | Hamilton Beach Big Mouth 70590 Food...
Toys Logo
43 people viewed this question
Top Worldtech Devices Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Worldtech Devices Toy Expert? Answer questions, earn points and help others
