Heatline vizo 24 heating problem
Hi. have a small problem with this boiler. put the central heating on and the boiler fire's up fine. it will heat the water up to temp in the boiler (6 red lights lit)(takes about 50 or so seconds) then shuts off, and does not restart untill the water in the boiler has cooled right down (1 red light)(about 2 to 3 mins), feed pipe gets hot real quick but the boiler shuts down befor the water reaches the rads. the return of the central heating never get's warm. preasure is ok. 1.2bar cold riseing to 2.6bar when heating up. the nearest rad will get warm but never hot. the pump is working fine and circulation seams to be fine. so basicly it does not heat all the water up in the system left on for 2 hours and all the rabs will get touch warm. i am thinking it could be 1 a faulty Overheat Safety Thermostat.. 2 a faulty pcb.. 3 that the anti cycling time may be set incorrect. any advise you can give may help. thank you.
  • Phillip Dann
    Phillip Dann Feb 15, 2012
    yep ok, have just noticed this is posted in the wrong place.
SOURCE: LCD Philips 26pf8946 after about 45mins right hand 1/3rd picture not viewable
Hi Darnez,
It sound like to me that one of the boards that power the bad side of the screen is getting hot and quitting. The boards are not too expensive to replace but getting them is generally the big problem. ( At least for our company). The set would be worth tkaing to a local shop and have it looked at, but replacement costs are going down every day it seems.
Good Luck
I hope in some way this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
Posted on May 28, 2008
  • 52 Answers
SOURCE: Red Blinking Light
These types of problems are allways hard to diagnose.. If you were to power on the set and preform tests, you would think that everything was fine until the moment it shuts off.
Look on the main power board and see if you cant find the thyristor (thermal switch), those are the things that when heated will cause the set to power off for safety reasons.. They are normally placed where ever a large heatsink is. That may give you a location as to the problem and you can put a meter around its 2 pins with the set off and unplugged a couple of min after failure, if its short (0 ohms) thats not the problem, if its open, it triggered the event.
Second, you can run the set for a while and check the voltages and Ve, Va, VCC, Vsetup etc and compair to the markings on the plasma PDP sticker. If you see one is falling down over time (volts will be lost as heat) then you can isolate that portion of the supply.
Third and allways the best way to go about these problems is buy a thermal gun and moniter various spots for heat.
Its just vary hard to say, resistance could be off somewhere, diodes could be overheating as well as fets and caps. Thats why a good thermal gun can point you to exactly where the problem is.
Hope this info helps, but I would suspect the problem is on the main power supply itself and not the y sus and z sus boards side boards.
Posted on Aug 26, 2008
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
  • 225 Answers
SOURCE: sony bravia-flashing red light
I would guess your power supply board is slowly disintegrating. It is hard to tell what it is, until it finishes frying itself out. Plan on replacing the power board soon, 1-3 months maybe.
Posted on Nov 14, 2008
Heatline vizo 24
Your cold water fill tube inside the tank is broken off near the top of the tank. Replace the fill tube.
Aug 26, 2014 | Water Heaters
Need to decrease pressure on a heatline plus 24 vizo? any ideas? also leaking small amount of water under boiler!
There is a pressure adjustment on the gas valve...make sure you set it with a manometer. If the water is just condensate, its ok except if you don't have enough combustion air for the btu rating of the water heater. If it is a leak, replace the water heater
Dec 11, 2013 | Water Heaters
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
I do not have a room thermostat connected to my oil fired central heating boiler. I want to install a wireless room thermostat to avoid having to run cable. how do i go about this and which is the best...
All wireless wall thermostats are Millivolt controlled. rather than having an 18 or 24 volt (transformer) wired wall thermostat. Before purchasing any wireless wall thermostat, you need to determine what your oil fired boiler requires for activation. My experience tells me, that it's going to require either 18 or 24 volts. In which case a wireless thermostat won't work.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
The boiler does not fire when hot water is selected although the red light is on. However the boiler fires ok when central heating is switched on and this does then heat the water. Is the problem in the...
Hi. and you are correct, if the boiler fires when the controller is set for central heating to come on, but does not fire when calling for hot water, the controller is either faulty, or not programmed properly. This is what tells the boiler to do on command, so, this is all that it could be.If you no anything about this controller as far as how it is set up, is it a programmable one, voltage on it, does it have wiring terminals on it that are labeled and can you get to them? If you can, and the wires are labeled, you can jumper them out to see if you can bypass the circuitry and get it to fire up on a call for hot water. This is the way to test it, very easy. You have to look at the wiring schematics to find the wires that are 1-hot and 2- hot water control. Jump across the 2 wires and if it fires, the controller is faulty. Careful if this is a high voltage controller as 120/208/230 volt. Check this out first. It can still be done, you just have to be careful not to ground yourself out. It maybe 24 volts. If it is higher voltage, you can kill power and get a insulated lead/jumper wire with clips on each end. Clip them to the terminals you want to jump out and turn on power. This way you are not touching anything. Please let me know the outcome on this and please when rating me as being helpful to you, be kind. I thank you. I will be here if you have more questions or need my help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jun 17, 2010 | Heating & Cooling
Ferolli HE 31C fires up fine, hotwater works, but ...
diverter valve fault most likely. when you call for central heating do you get 3 swiggley lines coming off radiator symbol in the boiler display if you do and not getting central heating then definitely diverter fault
May 20, 2010 | Quasar HQ2051TH Air Conditioner
To get heat downstairs i have to turn raiators off
Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
Feb 07, 2010 | Desa International CBN30T Central Heating...
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
