Question about Samsung Televison & Video
LE46N87BD Samsung 46in lcd hd tv faulty, item will not switch on makes clicking noise when you power it on?
  • 610 Answers
SOURCE: my samsung LE40M8 lcd tv won't turn on it just
sounds like a bad power supply board.
Posted on Nov 02, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 610 Answers
SOURCE: Samsung 52 inch LCD - no turn on just clicking
most likely the power supply board has failed, but it could be the main board as well. call 1-800-samsung for nearest service center.
Posted on Nov 25, 2009
Testimonial: "I open the TV (Samsung 52" lcd full HD) up. I noticed 2 1000uf 10v caps has expanded at the top. I replaced the 2 caps (77pence each). TV now work."
SOURCE: my samsung lcd tv wont switch on the on off switch
It sounds like a bad capacitor or more. Any bulging or leaking capacitors will require replacing on the board. These are cheap to replace, you can do it yourself.
Posted on Dec 29, 2009
SOURCE: samsung lcd tv just makes a clicking noise it wont
http://www.crovean.net/samsung-lcd-tv-power-up-problem another website on how to fix this clicking problem on samsung LCD TV.
Posted on Feb 25, 2010
Samsung LCD LN46C630K1F no red light and wont power on please help!
Check its main power regulator board. Replace it. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | Samsung LN46C630K1F 46in 1080p 120Hz Flat...
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
Turned the TV on this morning and it is making a clicking noise
I know exactly what the problem is. If you feel competent to do so..remove the back of the tv with the power disconnected for your safety. On the power board located in the centre you will see capacitors on the right of the board that have bulging tops..There are usually 4 of them that bulge (go faulty) like this..The value of each of these should be 1000uF..Replace these by buying from Maplins Electronics or CPC, both online..Solder new ones in (takes 10 mins) and all will be ok..
Feb 04, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Clicking noises before TV turns on.
The clicking noise is coming from the power supply relay. Is makes this sound when the TV is usually turned on or off but has become faulty. It will only get worse over time usually until the TV will no longer turn on anymore. You need to replace the power supply in order to fix the TV.
Nov 07, 2009 | Samsung LN-S4052D Television
My Samsung TV takes up to 2 hours to come on
Replace any swolen capacitor on the power board.
Sep 01, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung plasma
just to be sure, plug something else into the same wall socket to make sure you have power there. If you have power at the wall and the TV has a detachable power cord, try the TV power cord in your computer to see if it works. Otherwise you probably have a faulty power supply in the TV.
Aug 17, 2008 | Samsung LN-S4051D 40 in. LCD Television
Same problem: LA40R71B
Does it make the the samsung jingle when it trys to turn on? if it does you need a power supply if not then most likely it is the main board. I would contact you r local service center for help and if the standby lights in the front blink in a certain pattern write that down it is a error code that the technicain can use to solve the problem.
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
