Question about Toshiba SD-V394 DVD Player/VCR
Toshiba dvd player & vcr combo SDV394sc is stuck on the dvd screen, what can I do to fix this?
I have tried unplugging the unit but it still will only display the dvd screen. I can't use the vcr setup or anything else. I can however play a dvd.
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
SOURCE: DVD player does not read discs anymore
With some models of DVD player I know you can download a firmware update on your PC, load it to the DVD player and it wil fix some issues.
Finding those sites for download may be difficult though.
Posted on May 17, 2008
  • 4234 Answers
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Posted on May 21, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
We did use the Red & White RCA cable in addition to a coax cable. When the VCR tapes starts there is a burst of static coming from the speakers. The dvd sound is perfect but absolutely no sound from...
This is a combo unit (DVD/VCR), which should have RCA AV outputs on the rear - component video, DVD, and DVD/VCR. The latter output allows tapes to be heard and viewed, as well as DVD movies when the respective deck is selected via remote. There appear to be 2 S-video outputs on this model according to the user specs guide.
In other words, examine the rear of your combo unit - and connect the red-white RCA cable to the DVD/VCR 'OUT' sockets on the rear of the unit (L & R) and the S-video cable to the 5-pin socket in the same section if that is what you use instead of yellow RCA. This should fix the no-sound on VCR problem, and the bonus is it won't cost anything, and you don't need a workshop repair or setup quote.
You probably connected the cables to the main DVD output instead of DVD/VCR.
I hope this helps somewhat.
Mar 07, 2011 | Toshiba DVR670 Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Have a vcr/dvd combo. The door will not open on dvd player.
A disc may be stuck inside it, preventing it from opening. You may have to remove the housing on the unit and look inside the dvd area to see if there is something stuck. It could also be broken or not getting power. Try unplugging it for a few minutes than trying it again, as well as holding down the eject button for a few seconds. Be patient after each button press, as the player is programmed to stop the disc and "park" the laser before ejecting.
Hope this helps!
Jan 05, 2010 | Toshiba Televison & Video
Is there a way to adjust tracking for VCR play?
try this , while playing the tape , press ch+ & ch- both at the same time and watch the screen to see if it works , AJ
Nov 12, 2009 | Toshiba SD-34VB DVD Player / VCR Combo
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Jun 04, 2009 | Toshiba SD-V394 DVD Player/VCR
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Toshiba SD-V394 DVD Player/VCR Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
