Question about Drills
Mybrand new RZ20 keyless chuck will not close around a bit.
2nd time I'm asking! New chuck just won't function. I put chuck it in the collet, tightened it, and cannot get the three 'teeth' in the keyless chuck to tighten.
  • Mark Davenport
    Mark Davenport Feb 18, 2012
    Thanks. I tried it w/o a drill bit in the chuck and nothing happened. Is this a defective part?
    Genius:
  • 1,212 Answers
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Posted on Feb 18, 2012
  • John McPherson Feb 19, 2012
    Yes, if you tried working with it with no drill bit in it. I assume you tried forward and reverse just to make sure the collar was not jammed hard against a stop, that batch of keyless chucks has a problem.
Gigatech
  • 259 Answers
SOURCE: Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
Keyless Single Sleeve Chuck
Your tool features a keyless chuck with one rotating sleeve for one-handed operation of the
chuck. To insert a drill bit or other accessory, follow these steps.
1. Lock the trigger in the OFF position as previously described.
2. Grasp the black sleeve of the chuck with one hand and use the other hand to secure the
tool. Rotate the sleeve counterclockwise far enough to accept the desired accessory.
3. Insert the accessory about 3/4" (19 mm) into the chuck and tighten securely by rotating the
chuck sleeve clockwise with one hand while holding the tool with the other. Your tool is
equipped with an automatic spindle lock mechanism. This allows you to open and close the
chuck with one hand.
Posted on Mar 05, 2008
danny_murray
  • 55 Answers
SOURCE: porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Posted on Dec 05, 2008
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: chuck is locked in open position
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
Posted on May 25, 2009
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
I borrowed a die hard 19.2 volt cordless drill from a friend, but I can't figure out how to change out the bit! Can you help me?! Thanks!
Hi Mary,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
Good luck, Mary.
Thanks,
Handie Andie
Aug 15, 2011 | Craftsman 192 volt DieHard Cordless...
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
May 04, 2009 | Makita Drills
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Apr 27, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
292 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
