Question about RCA R56WH76 Projection Television
Rca p56927 colors out of line
The red blue and green lights dont line up. when there is words on the screen i see the words in 3 different colors. how can i line them back up??? set turns on o.k but colors separate and picture goes concave top and bottom.
  • Anonymous Jan 19, 2009
    We have the same problem with our tv! It happened yesterday when my daughter turned on our tv.
  • FSR49 Feb 01, 2009
    Mine is a r56wh76 with the itc222 chassis and I replaced fuse 231, but that wasn't enough. I ended up removing the entire PC board and resoldering all the terminals on the flyback transformer - it's on the same PC board. A lot of them had cracked. Incidentally, I couldn't find the exact fuse type (400ma), so I replaced it with a 1/2 amp (500ma) Pico fuse. I had the convergence option back and after doing an auto-convergence, everything was fine again. That was last October and it's still o.k. I definitely needed to replace fuse 231, but the final fix was re-soldering all the flyback transformer terminals.
    hope this info helps.
    FSR49
    Genius:
  • 1,030 Answers
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Posted on Feb 01, 2009
  • Willie Howell Feb 01, 2009
    just a minute ..which do you have r56wh77 or p56927 the fl231 problem only applies to itc222 chasis
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
Words on screen are 3 different colors blue red green, no picture just black screen when changing input and input channel words showing in diff colors
YOU may have two problems, 3 d picture or letters suggests convergence problem, Tell me more, all inputs have no function?
The more you tell me the better I can help.
I am expert with these sets and know them well.
SD TECH
Nov 06, 2010 | Mitsubishi WS-65807 65" Rear Projection...
My tv is showing in 3 different colors red, blue & green. and it has three lines at the top of the screen in the same colors
It seems to be that your dmd board might be going out, let's do this go to the menu and if you still have those colors, definitely your dmd board is taking its last breath :P but if they're not there, the issue is going to be with your video board
Jul 14, 2009 | RCA Televison & Video
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
It's most likely a failure of the convergence amp and some other power supply problem in the convergence circuit by the sounds of it... Your unit takes an STK730-130 and some 750k 1/4w resistors for the yoke return. I would bet two or more of them are out of value, at least R19702 and R19703... There are also two diodes Cr19710 and Cr19709. P/N# 164590 which commonly open under a load and are recommended to replace anytime the convergence amp is replaced. Also check Q19700 (Bc457) which crosses nicely to an NTE123a...
Not real expensive in a reputable shop - just a pain this time of the year.. I would recommend getting it repaired, it's worth it..
Bill
Feb 15, 2007 | RCA P56950 56" Rear Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
224 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
