Question about Toshiba Satellite A75-S209 Notebook
Toshiba A 75
Dim lcd screen
  • Toshiba Master
  • 32,281 Answers
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.
www.lcdparts.net
Posted on Feb 16, 2012
2 Suggested Answers
  • 256 Answers
SOURCE: dimmed lcd
Look for an icon on your keyboard that shows brightness like a sun drawn on the keys. try pressing that together with Fn key, or if you cant see that icon, try fn key and up arrow key or right arrow key. See if that one would work.
Posted on May 27, 2010
Toshiba laptop satellite A75 dim screen
LCD screens and Inverters are available from this WEB site.www.lcdparts.net
Feb 15, 2012 | Toshiba Satellite A75-S226 Notebook
Toshiba laptop screen very dim. Icons on desktop visible at angle. model Toshiba Equium L10-300
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 13, 2011 | Computers & Internet
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
Satellite L45-S7409, Screen is very dim.
Try reseating the lcd cable on the back of the LCD and also where it plugs into the motherboard. If you still can't get a normal screen and it stays dim then its going to be either your lcd is bad or the inverter that supplies the voltage to the lcd (inverter is located underneath the lcd, small rectangular board) is bad.
Aug 08, 2009 | Toshiba Computers & Internet
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Toshiba a135-s4487 when on battery the lcd screen flickers and dims considerably.
When it first switches over to battery, you will generally see a flicker. The dimness is normal. Most laptops are configured to display the LCD screen when on battery power to allow longer operation on battery power. This can be overridden in the Control Panel -> Power Options but doing so will reduce the amount of time you will be able to work on battery power. The time before it enters sleep mode is generally shorter as well for the same reasons.
Apr 14, 2009 | Toshiba Satellite A135 Notebook
Have a P105 S6164 bought used lcd screen very dim
With the replacement screen did you replace the inverter board? Many laptop screens also have a very small fuse built into their power connecttions. Check this also.
Apr 03, 2009 | Toshiba Satellite P105-S6104 Notebook
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Just replaced a cracked screen in a toshiba a105-s4074....when i turn it on i can barely see the screen....it is very dim.....when i plug the old cracked 1 up it works fine....any suggestions?
If you see a dim image on the LCD screen it means you have a backlight problem.
Mar 10, 2009 | Toshiba Satellite A105-S4074 Notebook PC
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
