Question about Panasonic NN-H764 Microwave Oven
Can't get past the "welcome" message.
I had the same problem as another posting... the unit would turn on for 3 seconds and then just shut down. I returned it to Future Shop and they sent it away. The work order says they replaced a 20A fuse and a diode. Now we plug it it in and it says: "Welcome to Panasonic. refer to operating instructions before use" over and over again. It never gets to the colon as per step 3 in the manual. I have tried everything I can think of... Please help as we have a newborn who likes his milk just right!!! Geronimo
  • Dan Moore Aug 16, 2006
    Hi Techman... thank you for getting back to me.... I agree that is the thing to do... but I cannot get past the welcome screen to set the clock... it is locked into the welcome screen...
    Geronimo
  • Cooked-goose Jan 13, 2009
    I have the precise same issue. Now, listen very carefully, none of the buttons work except the Stop/Rest button. When you press that, it brings up the " : " Collen icon in the display. However, NONE of the other buttons work. Not function, not clock, nothing. Then the message keeps scrolling by as the other person has stated. I have read in detail the owners manual and tried the child lock and demo mode suggestions. And yes even tried setting the clock but to no avail... because none of the keys respond. Thank you in advanced for any insight you may have. I would appreciate a thoughtful response.
    President:
  • 3,130 Answers
Go to the page in the owners manual to set the clock first. Thats always the first thing to do. Good Luck
Posted on Aug 16, 2006
Ge microwave m# pvm2070sm1ss. Control panel nonresponsive, attempting to check if creen lock is engaged but cant get past "change the filter"message.
I have never seen a home microwave that shuts down the unit to have you clean the air filter. Mostly they are reminders that stay up for a preprogrammed time. Have you tried to unplug the unit,let it set for a couple of minutes, Plug back in, set the time of day (clock ) and try it again?? If you get NO action from the touch panel, the touch panel may be bad.
Aug 24, 2017 | GE Microwave Ovens
Sumsung MU3250W shut down
The problem is your magnetron tube is leaking RF. The mag tube comes on 2-3 seconds after you hit start, and the RF interfears with the board and shuts it down. Drop the front of the control panel down and watch, it wont happen.. Get a new mag tube put in and you'll be good to go.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Starts then stops
Please unplug the unit's power cord and test a different power source. If the problem persists, use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Mar 26, 2014 | Panasonic NN-S763BF Microwave Oven
OUR AMANA Radarange. Has there been anyother complants on this unit. Any help would be appreciated. Any sugestions on whats wrong? If we try to use the microwave for more than 1 minute it shuts down in...
the unit has developed a power fault. This issue is related to a power problem in as much as the unit turns off on it's own.
The problem is consistent with overheating on the power supply board of the unit.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the unit to turn off on it's own.
When current passes from electric outlet to the power supply board of unit. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and unit shuts off on it's own.
It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to behave this way.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Sep 18, 2011 | Amana Radarange Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Panasonic NN-H764 Microwave Oven Logo
112 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
