Wiring diagram bose 610 series 2 speaker internal
  • 198 Answers
SOURCE: Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Posted on Mar 10, 2008
SOURCE: Bose COMPANION 2 Speaker case disassembly?
yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Posted on Jan 26, 2009
  • 71 Answers
SOURCE: Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Posted on Jul 26, 2009
kinkjc87
  • 51 Answers
SOURCE: BOSE speakers won't work with my HP Pavilion Desktop......help!
try reinstalling the software for them then make sure your sound card drivers are installed properly
Posted on Aug 10, 2009
DaveMc3
  • 32 Answers
SOURCE: I have Bose® Companion® 2 Series I
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Posted on Feb 08, 2010
Testimonial: "Good suggestion."
I need wiring diagram Bose audio input cable
Bose is proprietary. You need to either order it from them or Get a meter or continuity tester and write down the pinouts and make your own.
May 11, 2013 | Bose acoustimass 5 series II Speaker
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
When speakers are connected to the computer, they produce a popping sound every second. However, when headphones are connected to the speakers the sound works fine.
these speakers are quite problematic aren't they!! From the information you have given there is either a problem with the mains trans former or the internal wiring. Neither of which are user serviceable.
Jan 07, 2011 | Bose Companion 2 Series II Multimedia...
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
Jul 11, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
55 people viewed this question
 Grubhead
Grubhead
