Question about Amana Washing Machines
Loud racket type of noise - Amana Washing Machines
  • 3 Answers
Uneven laundry load or overloaded.
Posted on Feb 15, 2012
Why is my fridgidaire top loading washer so loud?
You didn't say when it was making the loud noise. During the wash cycle or spin cycle? An unbalanced washer will make a loud racket, too many clothes or actually not enough will make the basket bang around in there. If it has a center agitator, make sure it is tightened down. The screw is under the center Fabric Softener cup. That's the easy stuff to check. Now on mine, when you take the front panel off, I noticed that the hooks and springs that hold the basket up & in place and help keep it balanced, had actually over time had worn the round holes in the metal construction of the machine to oblong holes. Not much you can do about that. If the noise is coming from the motor, & you can't find a used cheap one, it would be more cost efficient to just use as long as you can and buy another machine. A loud noise could also be caused by a bad pulley. Hope this helps.
Jul 03, 2014 | Frigidaire GLWS1233A Top Load Washer
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
I have a 2005 ford focus hatchback.manual trans.it started sounding loud when i started to accelerate like a loud exhust had it checked said the cat was going out so they replaced the cat and manifold and...
You did not mention the muffler which is the most important one for keeping the noise down. The cat,converter's primary function is pollution control, not noise and if you had a bad manifold you would have a racket even when you were idling. Was the muffler changed ? If not then that was probably the problem in the first place.
Oct 23, 2013 | Ford Focus Cars & Trucks
Door won't lift when push button. Makes loud
if this is a chain drive,is the chain so loose that the chain is jumping on the sprocket? this would cause a lot of noise. if this is the problem just tighten the chain.
Nov 25, 2009 | liftmaster Chamberlain Garage Door Opener...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Loud buzzing noise during operation
Same thing happened to me today with our Kenmore 66515862990.
Probably there's something stuck in the drainage pump - in our case a tiny plastic domino was causing a heck of a racket.
On our model we needed a star type driver and a nutspinner driver to dismantle the unit, and a wetvac was essential to get out the water and offending blocking item(s). There's an exploded view of the water pump at searspartsdirect.com - see here - they have otrher diagrams. I had to dismantle down to part 25 in the diagram to get at the offending article. There are two white plastic balls i the assembly - these are NOT junk and they need to go back there when you are done. Take care not to damage the part number 40 or you'll get a leak when you are done. Hope this works for you!
Blessings,
Martin Francis
Dec 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Car noise: loud grinding/pinging. Louder when accelerating up to 40mph. Not as bad when idling/over 40mph
Could be anything from a bad knock sensor to an internal engine problem. Try a stethoscope test if you can duplicate this racket while in park.....accordianman
Jul 29, 2008 | Toyota RAV4 Cars & Trucks
Hotpoint condenser dryer making loud continuous noise whilst spinning
Pull the front panel off and check the roller wheels that the drum rides on. These have bearings in them that will eventually go bad and start to make a racket. They can be easily replaced and are usually sold at appliance parts stores in pairs.
Jul 12, 2008 | Dryers
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
