Question about Honeywell Heating & Cooling
Electric baseboard heater
I have the thermostat completely off and the 8' baseboard heater is still throwing heat but the 28" heater is off. They are both in the same room
What did I do wrong?
Not wired correctly
Posted on Oct 26, 2008
My electric baseboard heaters make a pinging sound which drives me nuts when I am trying to sleep! Any suggestions other than changing the unit? Thanks
Electric baseboard heaters heat by radiant heat. This mean the heater is heating the metal of the heater first which causes expansion of the metal. This will cause popping metal sounds becouse it is heating up. When it kicks off, by the thermostat, it starts to cool which causes contraction of metal. This will also cause noise. Most all base board heaters I have installed and worked on does this. Sorry there is little to nothing you can do. :)
Jan 25, 2011 | Marley HBB1004 Electric Baseboard Heater
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
I am puchasing a 28 YO home with electric baseboard heating. Will this be satisfactory or have there been much advancement made in baseboard heating used today?
To put it simply; any other heat source is better than your existing baseboard heaters. Yes, there have been sincere advances. Here is an informational website:
http://www.heater-home.com/FAQ_baseboard.aspx
Hope this helps some:)
Farmerbear
Aug 30, 2010 | Fahrenheat Electric Convector Baseboard...
I have a electric baseboard heater and when I turn the thermostat up, it heats for awhile and then the heater stops throwing heat but never reaches themperature. Changed thermostat and still the same...
you either have an overheat switch opening up prematurely or a bad connection that faults when it gets hot. Check all connections with the power off and try jumping out the safety switch to see if the heater stays on.
Feb 28, 2010 | Honeywell Heating & Cooling
I have electric baseboard heat that was throwing sparks and making a "burned bug smell". The unit in question is about 14 years old. The unit was "off".. It is summertime. I got up at 2 AM to use the...
No. The bugs caused a short inside the wiring. you nweed to pull it off and clean it out. Possibly mend wires. or replace the unit
Replacement isn't as expensive as your life. So My recommendation is just buy a new one.
Aug 23, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Electric hydronic liquid-filled baseboard heaters
The same comparisons with other forms of electric heat (i.e., radiant, electric strip baseboard, etc.) are the same. The difference is cycle time - the liquid-filled electric heaters turn on and off less frequently than strip-type to maintain thermostat temperatures. This also means that the unit's temperature will swing more widely than the desired average thermostat setting (the liquid's temperature will signal the thermostat to turn off power, but the temperature will continue to climb; similarly the liquid will signal the thermostat that it is cool enough to engage power but the liquid will continue to cool after power is engaged - similar temp swings with hygronic heating systems). Some say that the liquid-filled units are safer, but the manufacturer's installation guidance is usually the same between strip and liquid-filled so both pose an equal safety hazard.
Sep 21, 2008 | Fahrenheat PLF1504 Baseboard Heater
Installing tandem baseboard heaters
Yes, you should use only one thermostat per power source.
Nov 13, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
73 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
